Question about Tomtom ONE GPS Receiver
To much voltage put into tom tom.smell of burning
    Problem Solver:
  • 9 Answers
When you plug in the normal cigarette liter into the socket does it pop up hot? if so I suggest trying to replace the power cord to the tom tom. your car only puts out 13.8 volts. any more than that the fuses would blow.
Posted on Apr 21, 2008
Only had condensor dryer aqualtis aqc9bf7 1week very bad burning smell
could just the newness or fluf got into heater keep an eye on it good luck tom
Feb 15, 2015 | Washing Machines
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
My tom tom will not turn on
Possibly a voltage overload. You will be able to smell the buring at the USB socket power point. Needs to be sent in to the workshop for repairs and various chips and diodes need to be replaced
Feb 11, 2013 | Tomtom ONE 3rd Edition GPS
Tom Tom One XL. Wont start and smells of burning! Does it sound terminal?
sounds like it is time for a GPS upgrade, when you go looking for a new GPS consider this, I see allot more problems here on fixya with Tomtom than with Garmin units about 10 to 1.
Jan 15, 2010 | Tomtom ONE XL GPS
Burning smell came out of the Tom Tom 910. Now does not boot up on mains or car cigar lighter socket
The power supply or voltage transformer or possibly capacitor is burnt out. You will have to visually inspect the main control board for burn marks and swelled up capacitors. You can use an ohmmeter to test them as well.
Dec 04, 2009 | GPS
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
BURN SMELL NO PICTURE
Burned smell indicates some board level component has shorted and /or burned. Also, there could be high voltage arcing which has burned through the wire insulation. Safety circuit has shut down the unit to prevent further damage or fire hazard
Jul 30, 2008 | Televison & Video
Burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Tomtom ONE GPS Receiver Logo
79 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
