Question about Body Solid Aluminum Pulley Upgrade Kit for G5S Home Gym Weight Stack Machine
What are the parts of a pulley? - Body Solid Aluminum Pulley Upgrade Kit for G5S Home Gym Weight Stack Machine
    President:
  • Body Solid Master
  • 832 Answers
It is a fiber circular component with a center V- groove and uses a 6202 sealed bearings that the cable travels when utilizing the machine. The Upgrade is a complete replacement of all pulleys in the unit with aluminum pulleys
Posted on Jul 19, 2010
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
Serpintine belt diagram
what engine? Please rate if it helps
3.L v6
snorkelbobby_26.gif Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner 6 10344 Generator pulley
2.0L Zetec 4 cyl with A/C
snorkelbobby_27.gif Item Part Number Description 1 10344 Generator pulley 2 19A216 Belt idler pulley 3 3A733 Power steering pump pulley 4 6C301 Drive belt 5 2E884 A/C clutch pulley 6 6B320 Crankshaft pulley 7 8509 Water pump pulley 8 6A228 Drive belt tensioner
Jan 12, 2011 | 2002 Ford Escape
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Bottem pulley on engine block is making noise, I think the bearings are going out. What is this pulley attached to and can it be lubricated?
the bottom pulley is the crank pulley. It is attached to the crank shaft. It has two parts, an inner and an outer that are joined together with a rubber isolator. Over time the rubber breaks down and the inner part part of the puller will start to rotate independently from the outer part of the pulley creating a unigue clacking noise.
To solve this you'll need a standard crank pulley puller set. You'll remove the crank bolt and then use the pulley puller to pull the crank pulley off of the crank shaft. The install the new pulley making sure to torque the crank pulley bolt to the proper spec.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 06, 2010 | 1998 Buick Park Avenue
Need serpentine belt diagram for a 2005 Chevy Aveo
One doesn't need a serpentine belt diagram to thread a new belt to the pulleys.
Just note which pulleys are smooth and which have grooves in them, and 'thread' the belt loosely around the pulleys in a fashion where the smooth part articulates with the smooth part, and the grooved inner part articulates with the grooved part.
Do this until the last pulley is the tensioner pulley, which can have its tension released with a breaker bar.
Aug 19, 2010 | Chevrolet Aveo Cars & Trucks
Replace belt dont know how it goes dont have pic on how to put it back on pulleys
Hi you can go to www.autozone.com and join my zone for free and thay have diagrams.Thank You for using fixya.......iluv2fish...Ray....
Jul 16, 2010 | 2001 Ford Mustang
Serpentine belt diagrm
Not sure if you have the 3.0L 2V or the 3L 4V so heres both. Hope it helps.. Cobra,, :-)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8509 Water pump pulley 3 2E884 A/C clutch pulley 4 8620 Drive belt 5 6312 Crankshaft pulley 6 6B209 Drive belt tensioner pulley 7 10346 Generator pulley
Jun 05, 2010 | 2000 Ford Taurus
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
How to install drive belts to 1996 nissan quest
go here for help
http://autos.groups.yahoo.com/group/villagerquest/files/
Item Part Number Description 1 — A/C Compressor Drive Belt Idler Pulley Adjustment Bolt (If equipped)
(Part of 8678) 2 — A/C Compressor Drive Belt Idler Pulley Tensioner Bolt (If equipped)
(Part of 8678) 3 8678 A/C Compressor Drive Belt Idler Pulley (If equipped) 4 8620 A/C Compressor Drive Belt (If equipped) 5 2E884 A/C Clutch Pulley (If equipped) 6 10346 Generator 7 10344 Generator Pulley 8 11719 Generator Adjustment Bolt 9 — Generator Locking Bolt 10 8620 Generator Drive Belt 11 6312 Crankshaft Pulley 12 — Water Pump and Power Steering Pump Drive Belt Adjustment Bolt (Part of 8678) 13 8678 Water Pump and Power Steering Pump Drive Belt Idler Pulley 14 — Water Pump and Power Steering Pump Drive Belt Idler Pulley Locknut (Part of 8678) 15 3A733 Power Steering Pump Pulley 16 8620 Water Pump and Power Steering Pump Drive Belt 17 8509 Water Pump Pulley A — Tighten to 16-20 Nm (12-15 Lb-Ft) B — Tighten to 33-37 Nm (24-28 Lb-Ft)
Mar 28, 2009 | 1996 Nissan Quest
Body Solid Aluminum Pulley Upgrade Kit for G5S Home Gym Weight Stack Machine Logo
176 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
