How can I convert the temperature scale in Simple comfort 2000 thermostat from Celsius to Fahrenheit?
  • 121 Answers
SOURCE: Carrier thermostat
No this t-stat is not designed for low temp
Posted on Sep 30, 2008
mastatech
  • 478 Answers
SOURCE: AC Thermostat
If you have a maual go to the installer settings, Most manufacture have these manuals online
Posted on Mar 25, 2009
erincinci
  • 148 Answers
SOURCE: how to convert celsius temperature into fahrenheit ino c++?
Try using the simple mathematics; - C: variable for the Celsius Temperature - F: variable for the Fahrenheit Temperature
F=((9/5)*C)+32
Posted on Apr 17, 2009
  • 44 Answers
SOURCE: Thermostat reading
inside of most stats there is a switch that changes for F to C. some stats you have to into the installer set up program to fix it. if I knew what kind of stat i could maybe walk ya through it.
Posted on Jul 12, 2009
  • 74 Answers
SOURCE: thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Posted on Aug 30, 2009
How to change from Celsius to fehrenheit
On the Celsius scale, the freezing and boiling points of water are exactly 100 degrees apart, thus the unit of the Fahrenheit scale, a degree Fahrenheit, is 5/9 of a degree Celsius. The Fahrenheit scale coincides with the Celsius scale at -40 °F, which is the same temperature as -40 °C.
Sep 11, 2017 | Cars & Trucks
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
What is the fahrenheit eqivalent of 20 degrees celsius
Hi
To convert temperatures in Celsius to Fahrenheit:
Multiply by 1.8 (or 9/5) and add 32.
  • Your answer: 20°C x 1.8 + 32 = 68°F
Trust this helps, regards Alan
Jul 07, 2014 | Comfort Zone NEW 09 Electric Portable...
Explain the different unit of temperature and give the relation between them
You have the Celsius Scale characterized by
Freezing Point of water :0 deg C
Boiling point of water : 100 deg C
The Fahrenheit Scale characterized by
Freezing Point of water :32 deg F
Boiling point of water : 212 deg F
If F is the value of a temperature on the Fahrenheit scale, the corresponding temperature on the Celsius scale is given by
C= (5/9)*(F-32)
If C is the value of a temperature on the Celsius scale, the corresponding temperature on the Fahrenheit scale is given by
F= 32 +(9/5)* C
Nov 25, 2013 | Computers & Internet
The LED control panel quit reading temp and now has a range between 19 and 31. What does this mean and how do I convert it back to temperature? The brand is Comfort Aire Model #RAD101-5-B Thanks for any...
That is Celsius, rather than Fahrenheit. To return it it Fahrenheit press the temperature up and down arrows at the same time and hold for 3 seconds. It should return to Fahrenheit.
Hope this helped you and thanks for choosing FixYa.
Aug 02, 2011 | Comfort-Aire RAD-101 Air Conditioner
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
What is the formula for 32degree celcius to fahrenheit?
the formula to convert degree Celsius to Fahrenheit is
Tf = (9/5)*Tc+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
to convert 32degree Celsius to Fahrenheit is
Tf = (9/5)*32+32 = 89.6°F
Jan 21, 2011 | Office Equipment & Supplies
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
How to convert celsius temperature into fahrenheit ino c++?
F=((9/5)*C)+32
Apr 17, 2009 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
