Question about Toshiba TW40H80 40" Rear Projection Television
TV will not turn on
For some time since I got this TV I've been having sporadic problems with turning it on. At times it would click but would not turn on, I had to unplug it for a few seconds and plug it back and it would work fine. After a few year of service it will not turn on at all. I just had the diodes replace about a year ago. Is there a power supply or circuit board I could swap to fix this is am I pretty much done!?
Thank you,
  • Toshiba Master
  • 8,617 Answers
Sounds like a minor problem with the power supply. You can get the manual at this link, and they will provide free tech support to help you diagnose the set. Here is the link if youd like to order the manual and recieve the tech support for free.
http://servicemanuals.vstore.ca/
Posted on Apr 21, 2008
Left Turn Signal works sporadically
Could be the relay, But I have recently had a situation where the bulb was having poor contact in the socket, and it worked very sporadically. I solved my problem by removing my bulb, gently bend the wires on my bulb out like a rainbow, be easy, don't bend them much, just make sure they aren't flat against the bulb. Do both sides and repalce bulb. Worked like a charm for me!
Dec 13, 2013 | 2008 GMC Envoy
1994 Park Avenue intermittent starting problem
how long did the starter last for that you bought ??? if its still under warantee then get it replaced as thats where your problem is at
Feb 15, 2013 | 1994 Buick Park Avenue
'85 toyota pickup won't start
Hi with an old vehicle like yours, first thing which comes to my mind is the ignition switch and or a loose ground some where close to the battery.
Jan 08, 2013 | Cars & Trucks
I just purschased an Lg 26LV2500 and I can't get the military time off the screen when it is first turned on. I've set the clock manually with the month, date, and year and I've set the hour...
When you click on the clock icon the clock setting menu comes up scroll down to the bottom of the list if it is available it is two lines below the options on screen and change it to am\pm press return go back up the list and click option to set clock set clock press back /return then exit
May 14, 2017 | LG Televison & Video
Just purchased 2000 Buick LeSabre. 56,000 miles, sporadic trouble starting--sometimes starts first try, other times will crank and won't start and have to slightly depress the accelerator and then will...
If it runs rough all the time, could be a bad coil pack/wires. If just starting and hesitates on acceleration, I would suspect the throttle position sensor.
Jun 10, 2011 | Buick LeSabre Cars & Trucks
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Toshiba TW40H80 40" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
