Hi i wish to connect my tv and Cable connection
Hi i wish to connect my tv and Cable connection through only one cable. means from one wire i wish to have to tv and cable connection from one exit of digital reciver. is it possible
  • 8,457 Answers
No Vcr player,Blu Ray player desire right?Yes,u heard a Tivo box.Call ur cable company talk to them about it.
Posted on Jul 19, 2010
How to set up a cable box?
Connect cable wire out of wall to cable box input. Attach cable wire or HDMI cable from cable output to the appropriate tv input. Turn on cable box & tv. Goto source on tv and set it to the corresponding input that you connected to the back of the tv. If your tv does not have a HDMI input then you will not get hi definition tv. You can get digital. If you got a digital adapted you follow the same procedue but instead of a cable box you connect the digital adapter.
Jul 01, 2015 | Televison & Video
I want to see my TV
Do you mean that you wish to watch Cale TV on your projector? If so, the cable box must be connected to it. Usually using an HDMI Cable and switch box.
Dec 09, 2014 | Samsung Televison & Video
I have a ESA 427E TV and no remote. I have a Philips dvd player. How do I get it to work with this tv.
Hi there. Connect the player by means of a SCART cable.
When you activate the DVD, the TV recognises this and goes automatically into AV mode. About the scart cable: take a fully wired type. Then pin 8 is at least connected. This status pin makes the TV switch to AV mode. (toggles between 0 and 12V)
In some cases, it's only possible to connect the signals by means of RCA connectors. (red,black, yellow). Then it's more complicated.
You have to use the local "channel" buttons on your TV. Press the (-) button a number of times until you reach channels below 1. That's were AV inputs are active. Good luck.
Feb 15, 2014 | ESA ET427E 27" TV
Is it possible to connect PC wirelessly? If so, how? I can connect via wires but prefer wireless.
Hey william,
Ok. A portible computer can connect wirelessly as long as you have a router from a supporting cable provider. what this means is lets say you have cable from...xfinity. They will set you up with a router like any other company. This router pravides a wireless adaption to your computer that can last about 3 floors up and 3 miles away. Click the bars on your task bar and click "scan for available connections" and choose your connection. sadly you can only go wired but after that get a yellow support wire and plug in to the computer and hock it up to the TV and put the computer`s sleep mode off. this sleep mode will basicly turn off all programs and go to sleep cutting off the internet on your TV.
IF YOU WISH TO PUT YOUR TV WIRELESSLY THEN GO TO OPTIONS AND PRESS INTERNET AND CONNECT AND THERE YOU GO!
Apr 28, 2012 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I want to connect to a TV that;s already connected to a cable tv box
What do you mean? Do you want to connect or add another tv to that cable box?
Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
Hope this helps.
Sep 21, 2010 | Televison & Video
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
Cable connection
Just go to the dollar store buy new cable connector adapter it fits on end of cable so you can plug in & out / without breaking IF connector on tuner.
Aug 26, 2008 | Toshiba MD9DM3 9 in. TV/DVD Combo
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
