Question about Blaupunkt IDC-A09 5-Disc CD Changer
My IDC A09 CD changer won't insert or play discs
The factory fitted IDC A09 CD changer in my Peugeot 307 won't insert or play discs. The factory fitted Siemens VDO radio (an RB3) works fine but when the CD player is selected the display just shows 'Load CD1' and does nothing. If I press the '1' button on the radio it reads 'no disc'. The initial problem was a disc which fully drove in OK to slot number 2 but then just stayed stuck there and the CD changer wouldn't do anything at all. I had to remove the unit and open it up to remove the disc. There appears to be no problem with power to the CD unit as the red indicator lights behind the disc selection buttons light up OK. On the other hand there is no noise from the motors which don't drive the discs into the unit any more.
Does it need re-coding? (Apart from the Car Key there were no codes identified as necessary or supplied for the radio and CD when I bought the vehicle from the dealers).
4 Suggested Answers
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
Eagleeyes
  • 199 Answers
SOURCE: Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Posted on Jul 21, 2008
Warf135
  • 137 Answers
SOURCE: Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Posted on Apr 05, 2010
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Dec 14, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
will email you.
mark
Jul 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
134 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
