Question about Refrigerators
The freezer is cold, the fridge is around 50 degrees. The machine was recently turned on for the first time in approx 1 yr. It did ride on it's side for 30 mins. However, I did let it stand upright for approx 3 hours b4 plugging in. Again, the freezer is cold, the fridge is warmer than it should be, so it does not sound like a freon issue, does it? john 4109634792
  • 121 Answers
When not run for a while, or stored on its side..the oil AND freon can deposit into / or out of the compressor sump. This could take a day or a little more to fix itself. Otherwise your indication is of - low freon.
Posted on Apr 21, 2008
What settings do you recommend for the refrigerator and freezer/
fridge --around 4 ( should be at 5 degrees c and freezer around 6---minus 20 degrees c
for the fridge settings the numbers work down from hot --7 to zero --- 1 where as the freezer works from 1--- zero to minus to 7 really cold at -20
adjust each depending on the time the door is open and the frequency of the opening ---examples
if you find that lettuce is freezing at 4 and you are the only person using the door , put it up to 5 but if there a family and the door is continually being opened or held open while the minds are being made up , you may have to consider 2 or 3
Sep 18, 2016 | Amana Side-By-Side Refrigerator 26 cu. ft....
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
Why do both fridge and freezer stay at 50 degrees?
Can you provide the correct model number? Thanks that will help me see what controls your model has. I am here if you need me, Thanks John Tripp Appliance 911
Jul 30, 2014 | Maytag Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
I recently purchased a home. The kitchen has a
Firstly, the thermostats are usually calibrated at one elevation and where the fridge ends up may be above or below that so the number settings on the dial aren't that relevant. You should adjust the thermostat in increments then check the temperature after 24 hours, then adjust again if necessary. The fridge should be as close to 40 degrees F. as possible and the freezer about 26 degrees F. (if memory serves me). The heat you detected is the unit in defrost cycle and should be considered normal if intermittent and a problem if constant. There should be a switch to turn off and on the defrost feature if you determine it's a problem.
I hope this helps you and good luck.
Sep 03, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Not getting cool water from dispenser in door
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Samsung RS2534 Side by Side Refrigerator
Freezer is cold cold....fridge is at approx 50 degrees
Hello lmk400,
Welcome to fixya,
Haier HRF10 Top Freezer Refrigerator
You siad, your freezer is cold cold....fridge is at approx 50 degrees What could it be ????????
1. The first thing it could be is that you have a freezer that is packet to the ceiling.
And so full that it's articles are covering the air vents found in the rear of the freezer.
They are need to be clear for the cold air to circulate form and to the fridge compartment.
Yes that is correct!
The freezer and the fridge both share the same air and to restrict the air causes the other
to get warm.
And will eventually burn out your fan motor or possibly your compressor!
OR
2. Your fan motor is already burned out.
Try checking this and clearing the vents.
It will take some hours to get cold and all night to reach peak temperature, if this is your reason!
If not you should then try turning off the fridge AND, then unplugging it for five minutes.
This should reset the system if there is an electronic glitch!
If all this fails you may be low on freon and need service to add some.
If the fridge was left open a crack all night or all day by accident it will cause this!
or if you go shopping and while unloading or loading the fridge with the door wide open running back and forth to the kitchen table for some extended time to!
Gather all the cold stuff near the fridge and put them in quickly!
I gave you a lot to work with and I hope the first two suggestions are the fix and solve your problem.
Let me know!!!!
Huuum
Please rememebr to leave me a rating at our fixya site!
Oct 21, 2008 | Haier HRF10 Top Freezer Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
