Question about Samsung RS2630SH Side by Side Refrigerator
Leaking water model# RS267LASH leaking water from underneath...please help??
  • Anonymous Sep 03, 2008
    I took the back panel off from inside the unit to replace the fan. At the same time I defrosted the drain hole and keept pouring warm water through the drain to make sure all was clear. After one week water leaking again. Did the same all over again and in a week . same thing. There is no drain heater on the fridg side . Still freezing up around drain. Has a nice slope and good size hole. What now?
  • 121 Answers
Hi, When your fridge does a defrost cycle, the water is drained down the back..into a storage pan where it will evaporate. In your case the pan is missing or not flat...or the drain line is plugged. You will need to move the fridge from the wall, and open the bottom pannel in the back. There you should see the problem. While you are there it is a good time to vacuum and /or blow of the cooling coils for best efficiency. (I use a shop vac, which can also blow air)
Posted on Apr 21, 2008
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
I have a Kenmore Refrigeraor Model No.72132100 and I have noticed water leaking on the upper left shelf. I have tried changing the settings on the refrigerator and freezing setting but no improvements....
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 26, 2011 | Refrigerators
Hey i have a model TBF17PC top freezer and its leaking water on the floor.. opposite to the water trey. also water builds up underneath the vegetable trey
Leo Ponder
imufo2
Sep 14, 2011 | General Electric GTR16BBSR Top Freezer...
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
Leo Ponder
imufo2
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My Neff fridge freezer model K3965 is leaking - Puddles of water are appearing underneath and ice is accumilating at bottom off freezer. I have looked inside and can't see a leak but ocasionly can...
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Leo Ponder
imufo2
Aug 08, 2011 | Neff K3965XO Side by Side Refrigerator
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
My Samsung model RS267LASH has a small leak coming from somewhere on the bottom of the refrigerator. Is this normal condensation or a leak?
I believe it is a condensate leak. every time your refrigerator defrost the water follows a tube to a pan below the refrigerator. Im going to send you the manual and a link to click on to see what will be involved to help you resolve this, Sea Breeze
Nov 12, 2009 | GE Profile PFS22 33" Artica French Door...
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Sep 06, 2009 | Frigidaire Refrigerators
My washer is leaking water from underneath after it washes
Hi Please get me a model # so I can assist you.
Vic
May 27, 2009 | Washing Machines
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Samsung RS2630SH Side by Side Refrigerator Logo
414 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
