Question about Sony Cyber-shot DSC-W30 Digital Camera
The camera lense is stuck open and not will close
Our camera was accidentally dropped and since the lense is stuck open and won't close.
    Scholar:
  • 83 Answers
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Posted on Jul 19, 2010
  • Jonathan Agawin
    Jonathan Agawin Apr 21, 2011
    The battery of this camera might have not functioned. Replace it if necessary. if it doesn't work try to service the unit with a qualified technician in a service center.
Lenses on digital camera
yes its grain or sand only stuck in between the lens.
are you experienced in electronics for opening the camera?
Aug 10, 2008 | Nikon Coolpix 4600 Digital Camera
The lens is stuck, it doesn't come out
Hi, This is a very common problem with digital cameras. The lense is a very complicated piece that has motors sensors focus motors that can see clearly at a distance or close or in between. So any rough handling or trying to open lense in a case or pocket by accidental getting its on button pushed is a death sentence for lenses on digital cameras, dirt sand etc getting in the conical tube setup is not good either, they CAN NOT be mishandled if you think that that bump the camera got wasn't that bad the lense will have the final say and odds are it will say NO. Final thought is it's broke so try wiggling the lense with you fingers,tapping gently on a hard surface if it don't fix it it is still broke and probably to expensive to repair.
Nov 23, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My lens is stuck out and it will no longer take pictures. It is brand new!
The lens has either been hit, dropped against something, or the camera allowed to turn on while in a pocket/purse/case. The lense drive gears are plastic and not entirely substantial and require care - which most people especially teens and 20's don't give them. Once in this condition, they're done for. You can attempt to contact Fuji for repair, but you'd be responsible for the cost unless they're feeling especially nice that day, since there's simply no way for the lense to become jammed during normal operation - unless the lens is bumped or hit while open.
Since these camera require total disassembly, from the back forward, to get to the lense assembly, it'll be cheaper or near it to replace it than to repair it. Take it as lesson learned, and treat the next one with more care. NEVER touch the lense when open, NEVER allow it to bump anything, NEVER drop it, NEVER place it in your pocket or purse unless the power button is protected from being accidentally turned on.
Aug 22, 2011 | Fuji Photography
Shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
Dec 19, 2010 | Nikon FM10 35mm SLR Camera
Lense won't open or close
It is time to send it in for service if it is an expensive camera ($200 or more retail price) or throw it away if it is inexpensive. A repair for that may run $100, espcially if it was bumbed ot dropped and ther is mechanical damage. If it is under the warranty then definitely send it off.
Jan 30, 2010 | Cameras
Kodak M893 digital camera won't turn on
get a quote for repairs from a camera shop or junk it
The carry strap is not just for decoration but to place around your neck so that the expensive item doesn't hit the floor if dropped
Dec 02, 2017 | Kodak Easyshare M893 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
I accidentally drome my sony dsc h1, when i'm
Your lense has got mechanical problem. You need to open the lense and inspect for damage to the lense and clean all parts and puth them back together again. when you open it look for small fragments.
Good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
144 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
