Need a repair manual for the Xerox 2045 or 2060. Any ideas where I can purchase one? Thanks
    President:
  • 2,072 Answers
. To place an order, please call 800-327-9753. Thank you for your cooperation.
Explane to them what you would like.
Posted on Apr 22, 2008
Xerox Docucolor 12 Gear and sensor damaged
User manual can be found here. Service manuals can't be found for free, though.
May 12, 2008 | Xerox DocuColor 12 Color Copier
Anybody know technicians in NJ area for Xerox 700, please
Hi Oscar,
I see you bought a used 700i. I assume you didn't receive a maintenance agreement with the product.
I have some advice for you:
You can purchase a maintenance agreement on Xerox equipment new or used.
First contact:
Xerox Corp
101 Woodcrest Rd, Cherry Hill, NJ 08003
(856) 651-2000
Explain that you have a Xerox 700i without a maintenance agreement
and you would like a certified Xerox Technician to come onsite and
inspect your device to see if it qualifies for a maintenance agreement.
If your device can qualify it is more economically friendly to purchase
an agreement than it would be to have a tech go there and repair it once
Simply put, the one service call could be more expensive than a 1 year
I hope this helps and if you need more info get back to me...
Mar 06, 2015 | Xerox Office Equipment & Supplies
I need to change the fuser exit sensor assembly on my Xerox Phaser 7300dn. My actuator is broken and I have no idea to get the old part out and then replace it with the new part. Anyone have any insight...
If you are not knowledgable about the printer, I would suggest having a printer repairman fix yur problem.
If the sensors is not installed correctly, it will still not print and you will either have to ave a printer repairman fix it or buy a new printer.
The fix is not an easy fix for the average person to repair.
Sep 21, 2010 | Xerox Office Equipment & Supplies
Need repair manual for Xerox XC1044 copier
These manuals are usually only available to technicians in authorized dealerships. You might try ebay.
Jul 03, 2009 | Xerox Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Copier XC356 gives only all black copies.
WITH THIS PRINTER ITS CHEAPER TO REPLACE THAN REPAIR SOUNDS LIKE THE LED OR ILLUMINATIN LAMP IS BLOWN
Jan 23, 2008 | Xerox XC356 Copier
Xerox Docucolor 2006 Error Code 009-358
Solution Listing for Symptom The Printer's Control Panel Displays 009-358 - Contact Service Solution (try these steps in order) 1. Turn the printer off, wait 30 seconds and turn the power back on 2. The printer will need to be repaired power off the printer and contact service Not good news I am sorry to say. http://office.support.xerox.com/srvs/cgi-bin/webcgi.cgi?new,ques=User_Type:4,templateset=xo_legacy,kb=out98pkb,ques=obj(69892)::obj(707),ques=obj(34668)::obj(67237),Company={5AC8CA72-62D5-4658-8D6F-D2F393C98A63},varset=prod:2006 http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-2006/sprt-enus.html Good luck, Tim
Mar 15, 2007 | Xerox DocuColor 2006DPC Laser Printer
jasbo
jasbo
