Question about Sony HT-SL55 System
Sony Home Theater HT-SL5
I keep losing sound and the error message "PROTECT" flashes on the main unit. The system is routed through a freeview digital set top box.
Has anyone come across this problem before?
Regards,
tommy54
  • 2 more comments
  • pannekoek Sep 18, 2008
    Same here, I suspect the fan is not working and the system shuts down.
  • Anonymous Oct 06, 2008
    Same here, Ithe fan is working !! the system shuts down.
  • pumbweld Feb 14, 2009
    me to how do i get the system working again and what causes it????
  • Anonymous Mar 07, 2009
    va in protezione e si blocca
Same with me. What to do?
Posted on Oct 19, 2008
Samsung HT-TZ312 Stereo System flashes protect and turns off
Turn the unit off.....reseat connector at the power board (supply).After reseating, turn it on again and the protect error will disappear....I have this problem after repairing the optr16 power supply that accidentally plugged into 220v...only the 5q1265rf (power switch)and 9v zener diode connected at optocoupler being damaged. Hope this helps! Mhar fernando from the Philippines
Nov 26, 2010 | Samsung HT-TZ312 Theater System
SAMSUNG HT-Q9 displays PROTECT and then switches off?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.Hope this will help........
May 26, 2010 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Flashing code s/w chk
It is just that main unit is looking for the "Wireless sub-woofer" and shows this message when it can't find the sub.
wireless connection between main unit and sub should be reset.
Mar 11, 2010 | Samsung HT-X810T Theater System
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Sony ht-ddw750 protect mode on don't know why
Sorry for the bad news. It probably needs an output ic replaced.
Feb 23, 2009 | Sony HT-DDW750 System
Sony ht-sl5
If your problem is "switch on then after 10secounds shuts down and protect appears on the display .and cannot do anything with it but turn it off"
Then the unit is on protect mode, that is a special diagnostic mode that starts when the unit detects an internal fault.
To start unplug the unit from power for ten minutes, and see if this reset the protect mode, I guess you have done this already.
The first thing to do is to start the unit with nothing connected, if the unit does not go to protection, then the problem was one of the cables or a connected device.
If that does not fix it , there is a master reset , by pluggin the unit into main while at the same time you hold the power button.
If still no luck then the unit is defective and must be taken apart and tested with a multimeter.
You start checking for burnt areas on circuits, cold solder joints and leaking capacitors at sight, then there is need to grab the multimeter and do the real testing job.
When you find the problem you do the soldering.
Naturally this requires a certain experience in fixing electronics, to complete the job usually a precision soldering is needed.
Feb 17, 2009 | Sony HT-SL55 System
My DVD HT-Q9
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Home theater system hx-tx72
Bad speaker wiring.
Internal fault.
Regards.
May 30, 2008 | Samsung HT-TXQ120 Home Theater System...
Sony HT-SL55 System Logo
308 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
