Question about Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA
My intermatic works in manual position but it doesn't work on auto.isbrand new
You posted under Intermatic mechanical dial timer
Open following link for troubleshooting Intermatic timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Sounds like your timer is wired wrong.
Maybe wires coming from breaker are reversed with wires going to load
Add a comment with model number of timer for exact wiring help. And say what load(s) you are controlling, what voltage, and what color wires.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 28, 2011
Intermatic dial doesn't automatically switch sprinklers
1) Trippers can wear down. Transformer can go bad if model has 24Volt output. Relay can go bad.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
2) Add a comment Feb 2013 with model number, and include if this is new timer or older timer that worked before and stopped working.
Feb 10, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Intermatic WH40 motor not turning
call a local plumber to sort out the problem
it might be time for a new timer
Jan 30, 2018 | Intermatic WH40 - Water Heater Time Switch...
My EJ35IC timer seems to be preprogrammed, and i cannot erase it. can you help? thank you
There is no repair for defective timer.
Unknown if this is new timer, or timer that worked before and stopped working.
Add a comment any time.
Try resetting timer using instructions from manual: Move control lever to OFF-CLEAR position for about 20 seconds. Red indicator light will go off, and all previous programming will be cleared.
Then move control lever to ON position and red indicator will start flashing. Reprogram timer.
If functionality is not restored, then timer might be defective.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Timer has 1 year limited warranty fro Intermatic:
http://www.intermatic.com/customer%20service.aspx
Resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
Sep 18, 2011 | Intermatic Programmable 24 Wall Switch...
Manual switch works timer doesn't.
Timer that worked before and stopped working: could be clock motor or trippers
New timer installation: possibly the wiring from breaker box and wire to Load are reversed.
Open following links to troubleshoot Intermatic timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 27, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I installed a new Intermatic timer, model # T8805P101C, it works manually but the wheel doesn't turn to automatic set timings
If the dial does not rotate but manual override works, then the timer is wired incorrectly or polarity of line is reversed or you are connecting to 240Volt line instead of 120V.
1) You have wires from breaker box reversed with wires that goes to sprinkler solenoid. Switch black wires and see if that corrects problem.
2) Check that breaker supplying voltage is 120Volt.
3) Test if black wire from breaker tests 120V to ground wire, and test that white wire from breaker tests 0 volts to ground.
Open following links for additional troubleshoot and parts:
Jul 04, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
The mechanism that apparently trips the switch is loose: it moves from approximately the 4:00 position to 8:00 position manually and doesn't seem to be affected by the trippers anymore. Turns on and...
Problem is not clear and timer is not identified.
If I had to guess, the silver pointer is loose instead of stationary at 6:00, and the trippers are worn down and need replacement.
1) Open following link for Intermatic troubleshoot walk-through, and then add a comment:
With Intertmatic, Tork and Paragon metal box timers the trippers move the manual override lever back and forth.
Add a comment with in-focus photo of problem posted on flickr for more assistance.
Upvote the help.
Jun 07, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
Timer stopped working Manual mode turns things
Usually the timer motor is bad when that happens. You can purchase a new timer motor here (or at a similar website):
http://www.aplussupply.com/intermatic/timer.htm
If you don't want to mess with replacing the timer motor can can buy another time clock and as long as your existing enclosure is still in good shape, just swap out the guts.
Apr 07, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Logo
224 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
