Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
What is a f1 fault code ? - Hotpoint Aquarius WD640 Front Load Washer/Dryer
    Problem Solver:
  • 6 Answers
Hello, unfortunately an F1 fault is one of the worst faults that can happen it means the motor triac has gone short circuit and needs replacing. Probably best to get a Hotpoint engineer out to it
Posted on Jul 23, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Error code F1 F3 F6
    KitchenAid Fault Codes - AppliancePartsPros.com
    www.appliancepartspros.com/repair-help/kitchenaid-fault-codes.html
    Jump to Kitchen Aid Range / Stove / Oven Fault Codes - Failure Code, Fault CodeDescription, Solution ... F1 - E6, Latch signal mismatch error ... F3 - E0, Oventemperature ... electronic control will display F6 ...
    Jan 27, 2016 | Kitchen Ranges
    Nissan F1 fault code, what does it mean?
    "F1" was the fault code retrieved from WHAT by the auto shop?
    Jan 05, 2012 | Cars & Trucks
    Fisher& paykel F1 Fault code
    F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
    Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
    Washer flashes f 1 and will not start
    The range/stove fault code page....
    My Range is flashing a "F" something.....what does this mean??
    Some terms used on this page...ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction. Oven temperature sensor - What a common sensor or temp sensor looks like.
    Always remember Electricity is dangerous and should be treated with respect.
    Please pick a topic by Make and or problem...hope you find this helpful :-)
    A tip for the famous F1 fault code entr_anm.gif The biggest Fault Codes list that I am aware of! What does an oven temp sensor look like?Some info and tips on oven temp sensors
    Newer 4 digit fault codes - Maytag, JennAir, Magic Chef Newer Frigidaire fault codes new25.gif Some newer GE built in oven fault codes are here. Newest Hamilton built GE clock fault codes are here. I have some of my own hand written fault codes, here and some more here. The Maytag Gemini range fault codes are on this page. The Maytag Accellis range codes are on this page. traffic_record.php?lc=024041009290002517 A tip:The supplier recently reversed the display areas for the clocks. Therefore you may find an F1-E0 code or E0-F1 code depending on the model. They both mean the same thing, and depending on the model determines the code reference, and location of the F code. Different manufacturer of the clocks caused this.
    How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
    Mar 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
    I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
    Check the fault code status :
    http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
    F1 means Water supply/low water fill .
    Thanks
    Mar 02, 2010 | Washing Machines
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jan 08, 2010 | Kitchen Ranges
    F1-6 Fault Code
    This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
    Maytag Gemini fault codes.
    Fault code Suspect area Fault code Suspect area
    F0 - 0 None
    F1 - 1 Runaway cook upper oven
    F1 - 2 Runaway cook lower oven
    F1 - 3 Runaway clean upper oven
    F1 - 4 Runaway clean lower oven
    F1 - 5 Keypad cancel upper
    F1 - 6 Keypad cancel lower
    F1 - 7 Keypad disconnected
    F1 - 8 Keypad shorted
    F1 - 9 Slave
    Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
    F1-1 error on Jenn-Air Range
    if it is the stove that is in the picture the fault codes are in the door under the oven door.
    Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
    Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
    647 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
