Question about Microtek C593 15" Flat Panel LCD Monitor
Dummy holes in flat panle
Why?
    Problem Solver:
  • 5 Answers
Thake it back! These screens are cut from a large sheet. The expencive models are cut from the middel of the sheet, Cheaper models from the edges. Chances of a dead spot are greater on the edges of the sheet.
Posted on Apr 23, 2008
I cannot open the CD door on my Detrola KM837 4 in 1. I push the open button, sounds are emitted like it wants to work, but does not. Any suggestions?
agree with a small hole trick... but don't leave the drive ever empty. Use i.e. dummy CD media always. When you need it, just replace, spin your DVD, than put DUMMY back in the drive. Don't believe? Just try. :-)
proizvodnja raunara prodaja laptopova popravka kompjutera pc servis...
Sep 26, 2016 | Computers & Internet
Model un46d6400uf no picture or sound
Probably the power supply have some problem. check the link bellow to understand how to check the power supply of a flat panle tv.
Testing LCD TV Power Supply BoardsSTEP BY STEP
www.electro-medical.blogspot.com
Nov 03, 2015 | Televison & Video
POWER CAPACITY SIZE
The problem post of yours' has no sufficiant details to place a solution. Provide more details please. google.com/+GopakumarGopalan
Nov 02, 2013 | Pioneer SLX70C elite flat panl center...
Water on passanger side comin in, when going through a high pressure carwash! So had to change the Blower motor resistor because or the water pourring in! Is there a hole beneath the wiper motor
Hello. Welcome to FixYa. Please allow me to help out here.
Yes, there is a hole under the wiper motor. This is where the heater/defroster gets fresh air from.
If you are getting water in the heater box, the drains that keep the water from backing up, and entering the hole, are blocked. You will need to have the cowl panle removed, and any debris under the cowl removed and cleaned out.
Oct 04, 2011 | 2000 Toyota Camry
The handle broke off on my 2003 jeep grand cherokee laredo liftgate. how can i open it now? i can't find anything on the inside in the back and my tail light is out.
You will need to remove the interior panle from the loft gate to axess the latch
there is 4 screws along the bottom of the panle to remove then carfuly pull the panle away from the lift gate there is plastic clips that hold the panle to the gate these may need to be replaced when re installing the panle they can be purchased at the jeep dealer.
now look into the lift gate and you will see where the handle rod conects to the latch lift on this rod and the gate will open
to replace the handle remove the 2 10 mm bolts and disconect the rod from the latch install the new handle and rod to the latch install the 2 10 mm bolts. install the panle and 4 screws
this should cover it
Jul 13, 2010 | 2003 Jeep Grand Cherokee
I have a ford fiesta 1.4 lts and I have a lot of
Check the factory door drains at the bootm of the door. Should be 2 slotted holes at each end of the door make sure they are open. Sometimes they have plastic inserts in them just pull them out. The other way would be to remove the inside door panel and vaccum it out. Or drill 2 holes but that might make your door rott over a peroid of time. The door is tappered to drian at the slotted holes.
Jan 22, 2010 | 2006 Ford Fusion
Mtb2156bea leaks water down inside back wall of frig and onto floor
Hi, You will need to remove the rear panle inside the freezer section. You will find ice built up over the defrost drain hole. Remove the ice using a hair dryer (not a heat gun & nothing sharp!) Oncel the drain hole is visible, try and flush it out with hot water to be sure it is open.
I hope this helps you, Please let me know if I can assist you further.
Vic
Jul 09, 2009 | Refrigerators
Removal of interior door pannel on left rear door
Normal 0 Quite simple. Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
May 30, 2009 | 2001 Cadillac Seville
Getting rain water on front floor board,where are the drain holes for in the door panle?
there should be 2 drain holes. 2" from the edge of the door. it is a **** opening just above the outter door weld.
Apr 29, 2009 | Pontiac Grand Prix Cars & Trucks
Microtek C593 speakers
There are no speakers on that monitor. Those are 'dummy' holes.
There are no AUDIO IN jacks on the back either.
Jan 07, 2008 | Microtek C593 15" Flat Panel LCD Monitor
Microtek C593 15" Flat Panel LCD Monitor Logo
90 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
