Question about Cycling
When clicking into gears, chain does not go all the way to proper position on sproket and pedalling indicates, by sound and feel, that the gear is not solidly in place
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow links to have a detailed idea regarding your query..hope it helps….
http://www.wonderhowto.com/how-to-adjust-bicycle-gears-142013/
http://www.wikihow.com/Adjust-a-Rear-Bicycle-Derailleur
http://www.bikewebsite.com/rearder.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 19, 2010
Honda unicorn drive chain is jumping with extreme knocking sound.
Try checking the gearbox oil level and adjust the chain.
Apr 03, 2017 | 2005 Honda Unicorn
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
Knocking noise of chain in honda dream yuga bike when accelerating after shifting the gears. i have tightened the chain but still it happens.
That knocking noise could be that the teeth on your main drive are worn out and chain is jumping them on acceleration.Pull th primary cover and check the drive gear for chain on motor sprocket.Replace it if worn to that point.
Oct 02, 2013 | Honda Motorcycles
018c oiler
ck.the oiler drive gear behind the chain sproket
May 06, 2013 | Standard Oregon Chainsaw Chain For Stihl...
I have a Huffy bike with a 48cc motor on it. The chain hits my fenders and now keeps popping off
which chain is falling off. the one from the motor? if so check to make sure the sproket (ps i cant spell) and gear fom motor is lined up. on mine i remember having to flip the rear sproket. are you using the chain tenchiner pulley? i think the one that comes with the kit dosnt have a deep enough gruve. i got rid of it all together, and just made the chain fit with like 1.5 to 3 inches of play. ive seen people use the tenchiner from the rear shifting gear on a mountain bike. thats what i suggest. if its the chain from your pedals thats falling of the the guys from the bike shop are messing with you or the alined the wrong chain. or maybe you need to resize the chian they just got the wheel straight.
May 02, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
When i put power on the pedals i can feel a
Yes, but only YOU can determine which. Has the bike been maintained well so the drivetrain isn't worn out?
Does it do it in all gears or just some, like the one(s) you use the most?
Go here and look at the B-Screw adjustment...
http://parktool.com/repair/readhowto.asp?id=64
If the pulleys are too close to the cassette you'll feel clicking. Or if your chosen gear combination is such that the derailleur can't take up the chain slack.
http://parktool.com/repair/readhowto.asp?id=26
For creaks...
http://parktool.com/repair/readhowto.asp?id=98
Apr 27, 2010 | Cycling
Mongoose tactic mountain bike / loose crank on chain side. How to tighten.Chain ring moves with it. Makes clicking noise.
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Apr 21, 2010 | Pacific International Mongoose 26 in. Mens...
When pedalling the chain turns without driving wheel
you need a new coaster in the back rim. theres little gears inside that grab when you pedal forward and not backward. you stripped/broke the gears inside. take the back wheel off and if the sproket/cog spins both ways then you need to have it replaced.
Oct 20, 2009 | Cycling
Garage door drive stuck un up position
I found the chain extremely tight on the sproket. The mechanism had stalled hard against the stop bolt. I loosened the chain tensioner and the motor operated properly. Reset the limit adjustment so the mechanism stops a couple of inches from the stop bolt. Door is working fine now.
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Cycling Logo
18 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
