Question about NEC Electra Elite DTU 16D-2 Corded Phone
The voicemail system of the the Electra Elite 48/192 does not function at all.
  • 2 more comments
  • rsgirl Jun 19, 2008
    After 5 years, our NEC Electra Elite 48 does not answer calls, does not allow voicemail, does not allow us to transfer calls. It appears to have crapped out completely, and our supplier is quoting us upwards of $2500 to fix it.
  • Anonymous Sep 19, 2008
    When I dial into voice mail, the phone just rings and rings. I can not get into the administrators voice mail.
  • topper-weiss Sep 19, 2008
    I also have Electra Elite 48/192 voice mail, and I am unable to get into voice mail. It just rings and rings.
  • Anonymous Mar 26, 2014
    there is something going wrong with the phone there are 900 voicemails and they keep recurring as fast as we delete them. is there away to delete all these voicemail at once.
Is it the type with a hard-drive mounted on the card?
If so, pull the card out of the system, let it sit for at least 15 minutes, then plug it back in. You might even try putting it in a refrigerator (just don't get it wet).
If it still doesn't come back online, it's time for a service call.
I hope you have a maintenance contract, though.
Posted on May 10, 2008
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
Need to reset nec phone
Easiest way to reset the phone is to unplug it then plug it back in. If you are talking about resetting the voicemail associated with the phone extension, that's a little more involved.If you need the voice mail reset, you need to have the voice mail administrator (typically the receptionist) go into his/her voice mail and choose the MGR option if using the display "softkeys" and follow the prompts to reset the users security code or voice mail acct. If softkeys aren't available, follow the voice prompts to "system manager" and either delete the security code or reset the extensions voice mail entirely.
Jan 19, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
Voice Mail
We would first need to know what system you are using. Look for the system in a telephone closet or server room and their should be lettering on it, like ivs, ipk. Let us know what it is, than also there is a card in the system thats has lettering on it like vms, fms, vmp we would need to know what type of card as well to tell you how to access it. There could also be an external device, like pc, hooed to the phone system to run voicemail, but we need details. check out
Jun 01, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
IPK II system. Voice mail
if you mean calls do not go to your voicemail try hitting speaker key then dial 43 and then enter voicemail pilot number
Dec 26, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Electra elite IPK Problem
There are several things that could be causing this and it depends on how many conversations (ports) your voicemail can handle.
1. The voicemail ports could all be busy. Dial vociemail when you know nobody is using it. If you can get in then there is nothing wrong except that your voicemail system is busy and you may need more ports.
2. If you are pressing a button on your phone, then the button may be programmed incorrectly. Using the dial pad, manually dial the vociemail and see if you can get in.
3. As a last resort, you can turn the phone system off for 10 seconds and then turn it back on. Do this with caution however and make sure nobody is using the phones. You also run the risk of defaulting the programming on your phone system. If the voicemail ports have locked up, this will clear the locked ports. If this happens again (busy) hopefully it is under warranty as either the voicemail is going bad or is misprogrammed.
Dec 08, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Log into the voice mail server and you can reset the Voice mail for each account like it was a new account or you can delete the pass word on the account and then setup form the hand set. You do need to know the password to get into the voicemail server program. I believe as default it is NEC.
Sep 12, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
398 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
