Question about APC Back-UPS XS900 (BX900) UPS System
Fan noise like sound from APC XS 900 Back-up. Is there an internal fan? Appears to be functional, other then the noise that continues even when its turned off at the switch, or even unplugged.
4 Suggested Answers
  • 5 Answers
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
Posted on May 12, 2009
  • 5603 Answers
SOURCE: APC will not stop making noise even after I
Plug it back in and then turn the switch off before unplugging... It thinks you have a power failure when you unoplugged it.
Posted on Mar 12, 2010
tech240
  • 169 Answers
SOURCE: I have an APC XS
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Posted on Aug 13, 2010
How do I Remove battery on apc battery back ups bx900R?
If the batteries are swollen (overhead damaged), I would use a screw driver to gradually lever it out.
May 21, 2014 | APC Back-UPS® XS 900 (BX900R) UPS System
How to open an APC BX900R so I can replace the fan ?
slide the front bezel there is still 2 screws holding in there
Dec 16, 2012 | APC Back-UPS® XS 900 (BX900R) UPS System
Have a APC xs-900 that indicates overload and there is nothing plugged into it. New battery did not help.
change the internal fan its a 18-24V type change it with a ball bearing type and yes a 12 volt will also work, with 120v input fine and under medium load the fan is only supplied with about 15 volts and only reaches 24 volts if the load shoots up or there is a power fail situation
Sep 09, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
How to use apc rs 900 without battery
No no way to use the ups without battery it will not show mains supply without battery and you cannot use it as a stabilizer you must connect battery
Mar 09, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
How do i disconnect the RBC40 battery from the APC unit???
Typically, APC's have a removable from of back cover that may or may not be held in with a few screws (sometimes they just snap into place). Almost all of them also have a simply plug in connector for easy battery swapping.
You can even try the APC website seraching for the make and model they may have some tips there for you.
Oct 29, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Ran for about 15 minutes. Hooked up to one
Ether the unit is overloaded or the internal battery is given out, or the overload circuit has failed there are only 3 problems that it could be. Not to go to much in depth on this unit APC does have a garentee and I trust you will call them and tell them this exact same issue if they find the unit is faulty they will replace it even though it may be out of warrenty if you get them on the phone and explain to them they will help I know a Greg over there.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 12, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
APC Back-UPS XS900 (BX900) UPS System Logo
298 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
