Question about Fedders A7DH45B2A Dehumidifier
I need a part for an Edison DHE 25 Dehumidifier, where can I find parts? The float thing isn't working.
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
Need manufacturer n&a or amp draw for Edison dehumidifier dhe25wg
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Edison 40 Pint Dehumidifier
My Edison Dehumidifier does not draw any water. Everything is working great. Model: HDHE405, Type: D40, S/N 14393261 HM
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 22, 2010 | Edison 40 Pint Dehumidifier
Its an edison model emd40s year 200403 and the
Any float will work. Go to home depot and get a toilet float kit. -Good Luck Ned-
Sep 16, 2009 | Edison 40 Pint Dehumidifier
Have old edison 25 dehumidifier. can i put a tube
look for the drain hole from the collector pan under the tubes that fills the bucket, you could attache a hose there, by removing the bucket out of the way. newer models have a built in one.
Jul 24, 2009 | Dehumidifiers
Edison 25 dehumidifier coils frosting
Same problem with mine.I've tried to clean mine as well. HELP, I live in a very woodsy area and constantly fight humidy.
adrianam@wpa.net
May 12, 2008 | Edison 40 Pint Dehumidifier
EDISON 25
It's possible that the coil has become extremely dirty. It can be cleaned, but to do it well requires removing the external housing to better access the coil. I had a similar problem where the dehumidifier ran and the coil became quite cold but would not condensate. A thorough cleaning has it working as good as ever. Compressed air is not sufficient to remove the dirt accumulation, it must be physically scrubbed or rinsed from the surface. I used a rag pulled back and forth to scrub between the coils in areas where I couldn't reach to dislodge the grime with my fingers.
Apr 17, 2008 | Edison DHE55 Dehumidifier
Edison 40 Dehumidifier
Old post, but in case someone stumbles in here like i did, I need to point out that if an A/C needs to be recharged, then there has to be a leak somewhere, there is no use on recharging unless you find the place where is leaking.
Jun 01, 2007 | Edison 40 Pint Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
