Proscan big screen tv, 7 years old, has no audio unless watching a dvd. what is happening?
  • cic539 Apr 21, 2008
    i don't believe so.
    what other problems may that be? i tried unplugging etc. and it did not give audio.
  • 123 Answers
Unplug the set from the wall.........wait at least one minute & plug it back in....Doing this sends a reset pulse back to the micropressor to get it operating properly again. If this is the case...enjoy. If nothing changes, you got other problems.
Good Luck.
Posted on Apr 21, 2008
  • Amber Engman Apr 21, 2008
    What do you have all hooked up to the tv?
    DVD? Satellite? Tivo? Stereo?
    Check all the connections and make sure they are still plugged in.
    Check to see if mute was pushed on the remote.
    Let me know what happens.
  • 2,326 Answers
Do you have the DVD connected to a surround sound?
  • Jaime Hernandez Apr 21, 2008
    If you only have audio using the Video and audio inputs, that means that the audio amplifier is working.
    If you don't get audio using the RF(tuner) input, the tuner might be defective and will need to be replace.
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
When watching a dvd on our sony tv we have sound problems
how it sounds your tv's speaker syatem is going out or your rca cords going from the dvd to the tv are broke on the inside.
Aug 23, 2009 | Televison & Video
DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Jun 20, 2009 | Proscan 32LA30Q Television
Proscan tv
enter the user menu to see if you have text or telecaption on,if not your vertical section is possible at fault if the bottom half of the screen is blacked out.
Mar 19, 2008 | Proscan PS32500 32" TV
Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
Mar 07, 2008 | Proscan PS27108 TV
Audio not working on proscan ps61700
I have a GE 46 in TV that had the same occurrence. I believe it is a sign that the amplifier is overheated or stressed. The way I fixed mine was to unplug TV and leave off for a few minutes -then plug in. I discovered this by accident when the power went off one day and the sound returned (had been using my vcr audio output plugged into my stereo for weeks!) This fix will work for weeks-sometimes months-evidently resets the circuits inside the amp somehow. Last time this happened I also removed the back of TV and blew out the dust with compressed air while it was unplugged-still have sound 4 months later without a "reset"-so I'm guessing it did help .
Feb 29, 2008 | Proscan PS35660 TV
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
Dec 15, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
