Question about Cameras
I can't find my pictures on the computer after transferring them from my camera.
  • Cameras Master
  • 17,130 Answers
If you have transferred your images from the camera then it should have been transferred to your document files. Plase try to search for the images in the my pictures folderr available with all the users particularily with the primary user. If not from the start key click for the search key and search for images. All the images avaibale to the user should now down load. You can then locate the files where it is located and go on to the folder.
If you have any other image loading programs like the picasa , the images can be shared and found easily.
Please check again in your camera for the pictures if you have not deleted them and download once again by manual selecction to the folder. hope this helps. Good day
Posted on Jul 19, 2010
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: My camera doesn't transfer pictures to my computer
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
Kind Regards
Andrea
Posted on Sep 27, 2010
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
Kodak M763 how to transfer pictures from computer tp camera?
Use a card reader to copy pictures from the computer.
The camera is designed to capture pictures for ultimate transfer to a computer. It's not really intended to receive pictures from a computer. Thus the camera's data transfer capabilities are designed to go one way. To go the other way you need to use some other device, such as a card reader.
Be aware that if the pictures were taken by a different camera, or have been edited in any way, then the camera may not display the pictures. Opening a picture in a photo editing program and saving it without making any changes counts as editing.
Feb 03, 2013 | Kodak EasyShare C315 Digital Camera
I connected the cable and managed to transfer one picture from my Nikon S8100 to the computer. The computer tells me that there are no more pictures to transfer, but I cannot find them!!! Where should I...
When you connect your Nikon camera to your computer some program is automatically loading up and then transferring your pictures over. If you haven't deleted the picture from your camera then reconnect your camera back to your computer. Follow the same steps you did the first time but watch the screen carefully. When the program tells you it is copying the picture over it should have a window open to the directory that it is using for the transfer. You should be able to get to that directory in your computer to work with your picture.
If the program deleted the picture from your camera then just shoot another picture so that you have something to work with. Most programs use some kind of a naming convention when it is saving your pictures, Usually it is a name made up of the date you are transferring the picture on as well as a number. The program should open a window before the transfer is completed to allow you to use your own naming convention.
Jun 27, 2011 | Nikon S8100 Digital Camera
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
Jul 19, 2008 | Kodak EasyShare C315 Digital Camera
Pictures not transferred to the computer
The cause and solution may include one of the following: The AC adapter or USB cable is not securely connected. Check the connections, and then try transferring pictures again. Kodak EasyShare software is not installed. Install the software. There are too many programs running on the computer. Close all software programs and try transferring pictures again. The camera was removed from the dock during picture transfer. Replace the camera on the dock, and press the Transfer button. The Transfer button was not pressed. Press the Transfer button.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
129 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
