Question about Nokia 1661 Cell Phone
I am not getting ringing sound when i get a call. if i press the ringing tone button in tone settings my mobile will switch off, and automatically it will switch on. am getting alarm sound, but not getting vibration or ringing sound whn i get a call.... pls solve my problem...
  • 103 Answers
Go to phone setting and then go restore factory setting and press 12345 button wait for some minutes and access it
Posted on Jul 19, 2010
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
Mobile get switch off as entered into setting then tone setting then ringing tone so what will be the software problem and and will be the software code for it
RESTORE IT by typing *#7780# and after restore is complete then search again for ur problem if it still exists then switch off ur mobile and then again switch it on but before switching it on keep these keys pressed *456# or *,red key,green key hope this works
Oct 24, 2011 | Nokia 1209 Cell Phone
I dont know how to change my message tone in my mobile(noki 6681)
To set and customize the ringing tones, message alert tones and other tones for different events, environments or caller groups press the bottom-left button, and select Tools > Profile. Scroll to the setting you want to change, and press the center button. Scroll through the tone list and listen to each one before you make your selection. Press any key to stop the sound. Hope this helps.
Apr 08, 2011 | Cell Phones
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My fax is not printing of automatically
Press the on/off button once and it will switch between auto print on and the stored faxes will be printed .If you press and hold the fax will switch off.To switch the ring tone on-you go to the user settings and then rx settings select incomming ring and switch it to on.
May 15, 2009 | Canon FAX-JX200
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Nokia 1661 Cell Phone Logo
185 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
