When powered on the sandisk appears. Then appears a locked lock. I'm unable to perform any other task. How do I unlock the lock?
    President:
  • 1,561 Answers
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care
Posted on Jul 19, 2010
Take the lock off of a prison mp3 player
If you go to your browser type in " how do I turn off lock on my Sandisk View 8gb MP3 player , on the page that appears click on the top one that is the users guide for your MP3 player or do the following PRESS & HOLDTHE HOME BUTTON UNTIL AN UNLOCKED MESSAGE APPEARS, IF YOUR MP3 FREEZES DO THE FOLLOWING PRESS POWER BUTTON FOR APPROXIMATLY 15 SECONDS . HOPE THIS HELPS GOOD LISTENING .
Dec 26, 2015 | SanDisk Sansa View 8GB MP3 Player - Black
I forgot 4 digit password ... plz tell me how i unlock my LG T375
You can perform a hard reset.
if you perform a hard reset,all user applications and user data will be deleted
please remember to back up any important data before performing a hard reset
1.turn the phone off
2.press and hold volume down + power + lock key at the same time
3.release the keys when the factory hard reset screen appears
4.read the warning and press the power/lock key to confirm.press any other to cancel
5.press the power/lock key to confirm once more or press any other to cancel
6.your device will perform a hard reset
Now, it will be just like brand new phone, except any software OS updates you may have installed during your use.
Nov 10, 2014 | LG T375 Cookie Smart Touchscreen Unlocked...
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
Sep 18, 2013 | 2001 Toyota Land Cruiser
Just got a new Fuse. How do you unlock. How do you get to a manual?
Do you mean the SanDisk Sansa Fuze? The lock indicator is on the side of the MP3 player above the power switch. Move power switch to the center position to unlock. Push the power switch down to lock the unit. The user manual is available here: http://sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze . Click on the Additional Information tab. The direct link to the manual is http://sandisk.com/media/343157/fuze_um_0809_eng.pdf .
I hope this helps.
Jun 11, 2011 | SanDisk Audio Players & Recorders
What is the tiny black button on the back of my black berry storm for? Its behind the back cover.
New Power / Lock button usage
Using the Power or Lock button on the top of the BlackBerry smartphone, you can perform the following tasks depending on the state of the BlackBerry smartphone:
State of the BlackBerry smartphone: Unlocked and the back light is turned on
Action: Press and release button.
Result: Locks the BlackBerry smartphone and turns off the back light.
Action: Press and hold button.
Result: Turns off the BlackBerry smartphone.
State of the BlackBerry smartphone: Unlocked and the back light is turned off
Result: Turns on the back light.
Result: Turns on the back light and displays the power off prompt.
State of the BlackBerry smartphone: Locked and the back light is turned off
Result: Turns on the back light and displays the unlock prompt.
Result: Turns on the back light and presents the power off prompt.
State of the BlackBerry smartphone: Locked and back light is turned on
Result: Presents the unlock prompt.
Action: Press and hold.
Result: Presents the power off prompt.
Oct 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Key locked mode is on
To unlock it Press and Hold the Home button until an “Unlocked” Message appears. also Press and hold the home button to lock the unit, this can only be preformed when the unit is powered. good luck.
Oct 01, 2009 | SanDisk Sansa E280 MP3 Player
Does my sandisk adapter to make it work in lock or unlock position
If its a sandisk cruzer you may have to throw it away they are pretty bad and fail pretty easy, but you normally have to have them out in the locked position.
Aug 27, 2009 | Computers & Internet
Operation is locked, and I am unable to unlock
Go into menu an lock lock feature and turn it off.
Apr 25, 2009 | Televison & Video
50 people viewed this question
 Grubhead
Grubhead
