Question about Linksys Cable Modem
I unhooked computer to paint walls. Now
I unhooked computer to paint walls. Now reconnected, computer will hook up to internet but after a while drop out and I have to restart computer. diagnosis says modem is not connected to internet---so have pushed on the reset button on back (although it doesn't seem like it's being pushed) still have to restart computer and up for a while and back down again. Last time after only 10 months (I moved & i moved this stuff gingerly) I had to buy a new modem. What's up with these modems that once you hook them up you can't sem to move them again or out they go and you have to go buy a new one?!?!??!!??
  • Linksys Master
  • 4,930 Answers
I think you must be just unlucky.
I think the reset button just resets the wireless internet but I am not certain about that.
Usually when a router loses it's memory it needs a call to the internet service provider who will get inside it and reset the addresses and check the connections and so forth. This is usually necessary even if you own your own router rather than having one provided by the ISP.
Diagnostics says the router isn't connected to the internet so maybe that is the truth and the problem - coincidences do happen and maybe there is a fault somewhere on the line and it needs reporting to ISP so they can check it or get it checked.
It could be worth double-checking the connections and leads first. I recently had trouble with a phone that worked only when it felt like it. The trouble was a couple if pins in the master socket had gone green and was failing to make contact with the phone plug some of the time.
Posted on Apr 16, 2017
proton77
  • 1183 Answers
SOURCE: Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
Posted on Oct 18, 2008
SOURCE: I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: No link to pc or Modem
gzfg
Posted on Jan 31, 2009
SOURCE: Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Posted on Mar 13, 2009
eduverna
  • 7 Answers
SOURCE: configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Posted on Apr 13, 2009
Is recycled paint good for walls
generally speaking if the lids have been left on tight and you strain the paint with a stocking it will be ok but it might not smell to pleasant for a few days.try dropping in some perfume to kill the smell or a tea spoon of bleach will do suffice.
Jun 25, 2014 | Tools & Hardware - Others
A newly painted wall looks splochy, shinny in some spots and dull in others.
I would hope that you had the paint mixed well before putting it on and that the entire wall was done in one event. Also it would be of help to have primed the existing paint first.
Oct 21, 2013 | Computers & Internet
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
How to replace clutch on 1971 beetle
you will need to unbolt support bar, and bellhousing bolts. Pull back tranny, drop and you will have access to clutch and bolts. Make sure to use the plastic alignment tool when installing the new one.
Go to autozone.com and register for full free online repair manual
Sep 17, 2009 | Volkswagen Beetle Cars & Trucks
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Amp Turns off after 30 seconds of song play.
Check your ground and make sure it is grounded to metal in your car with no paint. Also, make sure you are running 4 gauge power wire. Another possible cause could be that the ohm load is too low on the amp. Also, if your car battery drops below 10v it will send the amp into protection.
Apr 15, 2009 | Kenwood KAC-8103D Car Audio Amplifier
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Reconnecting router
Connect your Internet provider to the WAN port
connect your COmputer to the LANPORT
Feb 01, 2009 | NetGear WGT624 Wireless Router
Westell 6100 modem not working for internet access
Unhooking the modem didn't jaz things up it was when the computer was repaired. You have to run the installation disk again or just buy a mac.
Sep 08, 2008 | Westell Wirespeed LiteLine 6100...
Linksys  Cable Modem Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
