Wipro tft moniter Model WLA170t display comes during power 'on' and within 10 seconds display goes 'off' But power LED always show indication of incoming signal and 'green'. tell me what componenets gone defective?
  • 317 Answers
SOURCE: compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Posted on Jul 31, 2007
  • 5 Answers
SOURCE: Screen powers up then goes blank after 2 seconds
Which TV input are you using?  On the LCT3285TA, the S-video and composite (yellow RCA jack) use the same audio input connections.  If you have a bad S-video cable, you might get this effect.
Need more information on how you are feeding signals to your TV.
Posted on Oct 31, 2007
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
  • 5 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Posted on Feb 17, 2008
  • 62 Answers
SOURCE: green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Posted on Oct 13, 2008
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
I have hp compaq nc6000 every time i switch it on it comes on and goes off within 5 to 10 seconds. there is no display when during yhat time. what could be the pssible cause
From the description this is a motherboard issue, a common problem with hp, at this point I would recommend having it assessed.
Jul 20, 2012 | HP Compaq nc6000 Notebook
How to unlock motorola 3G A1000
Try this: Might work.
Connect the phone to a powered Clip. Phone display should give "USB cable connected" message.
Press UNLOCK button on the Clip.
Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these two keys during "Waiting for PST" message, the Clip will give red E/G led and you will have to start with step 1 again).
After 1 and 2 keys have been pressed E/G green led will blink and the phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
Green E/G led glows. The cell phone is unlocked.
Axxx/Exxx/Vxxx unlocking noteDon't unplug cable right after phone reboot, wait until E/G led stops blinking!
good luck.
kc
Mar 11, 2011 | Motorola Cell Phones
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
My moniter display is not coming it alway show
You need to try this monitor on other PC to narrow down the problem, it can be the monitor, cable, PC. I f you try all the suggestions and it still does not work, then you need to open it up and see the pictures here: http://s807.photobucket.com/home/budm/allalbums
and check for shorted transistors or bad fuse.
Mar 11, 2010 | Dell E173FP 17" LCD Monitor
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Driver for Wipro Laptop
I have wipro laptop model no WIVNB7B1620. i have not driver for it. please help me.
thanx
Jun 22, 2008 | Dell Latitude D600 Notebook
Green led light flashing on 700p proview flat panel and no picture
Good Luck!
Feb 16, 2008 | Computers & Internet
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
