Question about Eidos Interactive Tomb Raider Underworld
PROBLEM AT THE MOMENT PLAYING THE GAME IN MIDWAY
A FATAL ERROR OCCURED DURING PLAYING THE GAME. WHAT WE HAVE TO DO .PLS SOLVE MY OROBLEM
How to sove the fatal error fatal error: Failed to load menumanager:'local:menusystem\mainmenu.qsc' please help me to solve this problem.
Yes that is out of memory the chips are running out of memory because of age you can reform it but it will not improve, sorry.
Jul 29, 2014 | Codemasters IGI 2 Covert Strike
Tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
on Feb 06, 2011 | Sony Playstation 3 (PS3) Console
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Mar 03, 2009 | Nintendo Video Game Consoles & Games
As error occurred during the start up operation (800010009)
You might want to start with trying to tell us what you were trying to do when the error occured... Anything involving a headset or playing Madden 08?
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Eidos Interactive Tomb Raider Underworld Logo
74 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Marvin
Marvin
seanwalters1
Level 1 Expert
nightwraithe84
nightwraithe84
Level 1 Expert
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
