Not draining properly and not taking washing powder from drawer
    Sergeant:
  • 288 Answers
Check hoses probably a coin or something stuck in it blocking the pump, you have to remove the back of the washer and take the hoses off at the input and output off the pump motor clean them and put them back on, try that.
Posted on Jul 19, 2010
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
There is caked washing powder let over in the tray after every wash and the clothes are not being washed properly. How do I fix this?
read the user manual for the right section to use
if you do not have a user manual then go google and type in ---user manual for ( make and model of machine ) and download a pdf version
personally washing detergent powder causes more problems that what it is worth
change over to liquid detergents
Oct 28, 2015 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
The fabric softener drawer on my hotpoint hd420 is not draining. At the end of a wash the fabric softener drawer remains for of water. Can you advise?
It is not that unusual to find some plain water remaining- has the softener gone OK?
If not here is just a quick POSSIBLE (1st) solution if you have not tried it already-
Completely slide out the drawer - normally made possible by pressing down the plastic flap at the backend of the softener part of the drawer - as it is normally in the middle.
You may find 'gunge' made up of washing powder (if you use powder of course!) and softener combined in the tube that the softener should syphon into. Wash out with plenty of water!
I do this to ours fairly frequently.
Hope this helps.
Jan 22, 2011 | Washing Machines
The washer is leaking water. It looks like it may be coming from the area where you put the dtergent into the detergent cup. I bought it at Bernie's and I think it has an exteneded warranty but I can't...
If you have water coming out of the detergent drawer, then i would suspect a clogged drain hose at the back of the drawer. If you take the lid off , (disconnect from mains ) at back of drawer small hoses take the soap powder to the drum. these can block with soap powder, ( gently push some wire or flex down pipe) dont pierce the pipe , be gentle. had this problem myself.
pete
Nov 17, 2010 | Whirlpool GHW9400 Front Load Washer
Washer doesn't dispense fabric softener
This can be either one of the solenoids in the dispenser has failed, the timer is not sending the signal to let the softener in, or the water is not circulating through the dispenser to flush it through. The water hose to the dispenser will occasionally plug up. Check the hose first, it's the cheapest to unplug it. ;-) Oh, I have seen the wires to the solenoids just simply come unplugged too.
Jan 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Every time I use my Zanussi Aquacycle, the water does not disperse from the washing powder drawer. This means I have to keep taking the drawer out, draining it off and putting it back before I use the...
It sounds as thiough the hose that lets the water into the drum from the dispenser is blocked with undesolved soap powder, you need to remove the top cover, and clear the blockage in the hose.
Please rate my solution.
Thanks.
Nov 09, 2009 | Washing Machines
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Overflowing drawer on washer
hi i had this problem at the very bottom of the washer inside is a pipe and in their is where it drains through there is somthing blocked could be fluff etc it is a pig to do
Apr 14, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
