Question about Philips 9P5034C 50" Rear Projection Television
Phillips 9p5034c103 green light comes on. No picture and no sound. what can be done?
  • 3 more comments
  • bigjack21 Apr 21, 2008
    I have the service manual what next.
  • Anonymous Apr 27, 2008
    1. have phillips projection tv 9P5040c1 no picture no sound green light comes on but thats it .I took back off checked fuses ok did not see any thing to be burnt on boards .Please help don't want to trash
  • Anonymous May 20, 2008
    TV does not have any power.
  • stefaninicol Dec 06, 2008
    green light is on but no picture or sound
  • hollanddiane Apr 02, 2009
    I have 9P5034C101 SN 23090363
    have green light but no picture or sound. Repair man said something about high voltage regulator is bad and would need to send square board to be cleaned and repaired then sent back to him for installation. If he need to "charge" TV it would cost $600.00. If no charging then it would only cost $500.00. Does this sound reasonable for a TV built in 1998?
  • Philips Master
  • 8,617 Answers
The stand by and start up voltages will need to be checked. you can get the service manual at the following link.
http://servicemanuals.vstore.ca/
Posted on Apr 21, 2008
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
My phillips mangnavox 9p5034c103 the picture is only orange color i 'cant adjust the other colors?
The fluid in the lenses needs to be repalced. This is common. You can get parts and repair instructions from http://www.TvRepairKits.com
Feb 23, 2011 | Philips Magnavox 51MP392H Rear Projection...
There is no picture on the screen the green light is flashing for it to come on then the sensor next to it turns red any help have changed the batteries in the remote and still no picture or sound thank...
It seems like the bulb needs to be replaced, the bulb you are looking for is a Phillips UHP 100w/120w 1.0 bulb, you can google the make and modle of the tv and you will find sites for the bulb or send details to info@soundandvisionav.co.uk
May 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Philips Magnavox model # 9P5034C103
Thats usually related to the center opto coupler . I will research it and let you know the part number in an hour or so. Its a very inexspensive part and easy to replace.
Aug 03, 2008 | Televison & Video
Dull vedio reception on rear projection tv
I have the same problem as Nadeem, but mine is green and blurry,,,,
Apr 21, 2008 | Televison & Video
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
