Chilled air flow is changing to warm air flow periodically, approx. 3-4 min chilled then 3-4 min warm as ambient air temp.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Sounds like a classic floating restriction. An A/C unit with a leak on the low pressure side can **** in moisture which is then pumped through the system, as it goes through the metering device, typically a capillary (very thin) tube, it freezes, creating a blockage. The discharge air warms, the ice melts and circulates again. During the circulation, you get cool air.
The problem could also be electrical. A faulty overload device or the compressor in the process of failure, could give these symptoms. Best thing to do is shut it off and have a pro take a look. If it is a window unit, look for a local refrigeration school to check it out. THey will often do the repair for the cost of the parts.
Posted on Jul 19, 2010
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
CSCP5UGXSS water temp
Hello dharitos1. I understand you are concerned about the temperature of the water in your refrigerator. Since the line runs through the door, the water will be slightly chilled, but will not be cold. You may need to run the water through a couple of cycles to get the chilled water. This is normal. I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
May 24, 2012 | Whirlpool GS6NBEXR Side by Side...
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
We have recently had three problems with our three year old Carrier 24 ACA airconditioner that I believe has led to it no longer producing the low temp. chilled air it did when it was installed. !. water...
Your air temp should be at least 20 degrees cooler than the indoor air temp. This is ideal. But it sound like your unit is low on freon. When units get low they will freeze up. They will also freeze up if air flow is restricted on the inside coil or the fan quits on the external unit.
Aug 08, 2010 | Carrier 38CKC024 Air Conditioner
Turn it on green light comes on beeps 3 times red light comes on then flashes
yeh thats the red ring of death temp solution is turn on wrap in towels so it nice n steamy then after 30 mins put in fridge til chilled or leave to cool it will reset the system only temp prob will come back and will have to be sent off to microsoft hope temp solution keeps ya goin till its sent off
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Refrigerator is not cool
First you need to measure the temp in the frig. Place a thermometer in a glass of water overnight or in a jar of pickles. If the temp is not below 40 deg F it is too warm. It could be anything from the fan running too slow, to frost buildup due to failed or failing components in the defrost circuit. If the thermostat is all the way up and everything else is working properly it could be the thermostat. Make sure nothing is blocking the places where the air enters and exits th refrigerator from the freezer. Please let me know what you find.....Eric
Jun 09, 2009 | Refrigerators
Warm air
A mechanical drawing of the system before installation (assuming an architect drew and approved the plans) should be at the malls office. Also the building inspectors office may have a copy of them.
The basics of chilled water are not too differant from standard HVAC with direct expansion - Air to Air systems.
If everyone else is having no trouble and are on cooling now I believe you may have a main valve closed but the handle may be showing it ts open. I woudl let the supers mechanic check this ans effect any repairs needed. It should be in your leas as to how to proceed with such items as this. If some stores are not on AC yet your piping may be on a 2 pipe system and the whole gbuilding has to either be on cooling or heating and you cant have both at the same time in a 2 pipe water system. This should have been disclosed to you at time of leasing though. Ask if the last tennants had AC trouble in the area you have. And ask if your system is 2 pipe or how many there are (up to 4 for each chiller / boiler system). A 3 pipe system is not uncommon and you could have both running at the same time in differant places but with reduced capicaty and higher utility bills so it is doubtable this is a 3 pipe system unless it is a really old building.
May 05, 2009 | Heating & Cooling
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Freezer too cold
I assume 'too much ice' means unwanted frost.
It isn't the temperature causing the problem although the recommended temp is around -5 since lower than that doesn't seem to help food keep better. First you should look for a balance control that determines the flow of chilled air to the two compartments. The temp control will influence both of them so there is somewhere a control that allows you to influence the ratio between the two.
I don't recall seening any combined freezer/refrigerator without one but if you can't find one, check the gasket seating around the door to see if it truly still flush all the way around' it doesn't take much gap to let the compartment pull moisture out of the ambient air.
Sep 15, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
