Question about HP LaserJet P3005n Printer
When idle for a few hours everything freezes - HP LaserJet P3005n Printer
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • HP Expert
  • 217 Answers
A wel known problem for this type of machine. I'm afraid you'll have to replace the formatter board. Partnumber: Q7848-69006
Posted on Jul 21, 2010
Fridge will freeze everything every few days. Turning it off for several hours will reset and fix it but only for a few days. Been doing it for months regardless of how much food is in the fridge.
Either you have a bad cold control or a failed damper witch will cause this issue. Most likely a bad damper though, locate the air vent top middle of the refer section and check to see if its wide open. If this does not close it will cause freezing. Good Luck
Mar 05, 2016 | Hotpoint FFM90 Bottom Freezer Refrigerator
Where can I get my hard drive mended it just ticking and will not work
I've had a pretty good success rate with freezing drives to recover data from a dying/dead drive. Much simpler and cheaper then most other methods of data recovery.
Freezing the drive shrinks everything inside, sometimes freeing up stuck/seized/trapped components, or keeping an overheating component from shutting the drive down right away.
Stick the drive in a ziplock bag(to seal out moisture) in the freezer.
While it's freezing, set everything up to quickly transfer your files off the drive if it does work. After a couple hours in the freezer, plug the drive in and see what it does. It may only work for a few minutes, for hours, or weeks. Pull your data off as fast as you can, if it stops again, re-freeze it and start where you left off. I've frozen drives 3-4 times to get everything off.
Dec 04, 2015 | Iomega Prestige Desktop 500 GB USB 20 Hard...
Refrigerator is freezing everything
try tuning the control to a lower setting . if on 5 go to 4 or 3
Feb 06, 2015 | Kenmore Refrigerators
Why does my Dell Inspiron 530 freezes up after being on for a few hours?
Check your battery status. It is possibly overheating whitin time and causing malfunction.
Oct 25, 2012 | Dell Inspiron 530 Desktop Computer
My 2008 chevy equinox is running fine at an idle but when i accelerate it startes to kinda sputter or bog out a bit, just like the gas was freezing up. i dumped in gaslin anitfreeze and let it idle for a...
Ever wonder what 10 oz of anything, would do
in 18 gallons of fuel (nothing)
Ever actually see gasoline go into a solid
frozen state?
How about spark plugs
Ignition Misfires
Having your vehicle diagnosed,just to
see If you have any issues???
Feb 20, 2011 | 2008 Chevrolet Equinox
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
Fax Machine freezing
TRY REPLACING SMPS (MAIN FILTER CAPACITOR) --IF NOT SOLVED THEN REPLACE THE MAIN PBA(MAIN BOARD), HAPPY FAXIONG OMNIPRESENT
Apr 13, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
HP LaserJet P3005n Printer Logo
306 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
