Question about RIM BlackBerry Storm 9530 Smartphone
Issues charging using USB and Computer
My blackberry storm wont charge when connected to a computer using the USB cable
    Problem Solver:
  • 11 Answers
Solution is to install only USB driver, so that PC recognizes the Blackberry correctly, and can also charge the device accordingly.
Try and download usb driver for windows xp or windows vista
Posted on Oct 25, 2010
My Blackberry 9530 start charging the moment it lights up with one bar it stops charging.It is giving me headache
Try to test another battery, might the battery is weak due to overused and long time usage.Try to check your charger,better test and use a usb cable then connect it into your computer then check if its charging normally,if its charging,that means charger is the problem and needs a replacement.also check the usb charging terminal pins if it is clean and align well.clean it if its corroded or rusty using a cotton and any rust solution,be sure to remove battery first before doing it to avoid short circuit.
If this two option does not work,consult a mobile service shop near you for a complete diagnosis and solution so it will be fix right away.
If you have some questions, feel free to ask by replying here. Thank you for visiting FiXya.
Jul 05, 2011 | RIM BlackBerry Storm 9530 Smartphone
My blackberry phone wont power up or charge
It probably wont power up because it wont charge. the USB port may be bad preventing it from charging. I assume you have tried both the wall charger and the computer connection and have not had any luck with either one. Its probably the USB port has stopped working. common problem if the USB cable had been yanked or severely stressed while plugged in to the phone
Feb 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
My radio seems to turn off randomly, and i cannot call/text/email/browser or anything. i can't even charge it, it wont connect at all.
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your battery http://www.amazon.com/External-Battery-Charger-Blackberry-Pearl/dp/B001RW4ZT2/ref=sr_1_5?ie=UTF8&s=wireless&qid=1263526365&sr=8-5
Jan 15, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
It wont charge and it wont save picyures and
If the issue is still present after all this, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 13, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Unlocked Blackberry storm 9530 EDGE issues. Rogers network
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues like this.
Jan 09, 2010 | RIM BlackBerry Storm 9530 Smartphone
Will not charge
Are you using the AC Adapter, or USB sync cable to computer to charge? If using your computer to charge, you will need to have USB Driver for your BlackBerry Model installed. Download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5It
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your Battery http://www.amazon.com/Blackberry-External-Battery-Charger-8300/dp/B002YGYLA8/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263514496&sr=8-2
Dec 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm-jum error 523
Oct 13, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My PC doesn't acknowledge my blackberry storm is connected. Blackberry Desktop Manager works, but nothing else does eg. Rhapsody, Windows Media Player 11. When it's connected it doesn't show in "My...
You have to isolate the problem. Please follow the steps below:
1. Connect the Blackberry into different USB port of the computer.
2. Try connecting the phone in to different computer to test if there's really a problem with the phone.
3. Try using different USB cable for the phone.
4. Check the user manual to see if you need to set it as "Mass Storage Device" before connecting it to the computer.
Otherwise, you need to consult the phone manufacturer for some advise.
Have a great day!
May 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
1,278 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
