Question about Mitsubishi WS-65711 65" Rear Projection Television
No sound, remote locked or not working?? and i cant get the menu to work on the tv itself, the volume is stuck on 0, cant move HELP
The buttons on the front of the set fail, (like mine did) even if they never get used. Probably the 'DOWN Volume' in your case is stuck closed. Try pecking on it first. My remote stopped working but so did the manual buttons too. While poking around on stuff I swished my finger across the buttons and it all started working so I knew I was on to something. I never figured out which one was the culprit as it continued to cause problems and was replaced as a complete unit under warranty.
The other quick check/fix is to remove the trim plate around the button plate (pop out stays like the speaker covers) , then remove the button assembly (3 screws plus pop out stays like the speaker covers) then unplug the multi colored lead from the button circuit board. This puts the Remote back in control and it will work just fine like this, minus manual control of course.
Posted on Oct 30, 2010
Lost remote tv fpa lock is on tv has solid red light help
This is the method to unlock an RCA tV:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Nov 23, 2012 | RCA Televison & Video
We cant play dvds in it because it has a lock on it and we cant get the code to be able to unlock it can you help us
Try the following methods. One of them should resolve your issue.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Regards,
G33k
May 09, 2011 | RCA Televison & Video
My son some how used the universal remote to set the pass word on the V-chip controls. Now I am locked out and cant get any channels.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 05, 2011 | GE Televison & Video
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
When i turn my tv on it says FDA Lock ON and then it turns itself off and wont come back on. it shows the power button is lit up but it has no picture and no sound. we have tried to reset the password to...
Hello
Your TV is locked I thinks. Do the following and see whether it help you.
OK.
Dec 20, 2010 | RCA TruFlat 27F520T 27" TV
42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
May 19, 2009 | LG 50PC1DR 50 in. Plasma HDTV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
How to reset parental controls
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Apr 29, 2008 | RCA 27V530T 27" TV
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
Mitsubishi WS-65711 65" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
