Question about Motorola Mobility V66 Cellular Phone
How do I remove the sim card from my motorola V66i mobile phone? I have found it under the flip cover, but can't get it out.
  • Dennis Fregger
    Dennis Fregger Apr 12, 2014
    To remove the sim from your Motorola V66i you must remove the FRONT panel (with the phone closed) - NOT the back! Just stick your fingernail under the edge of the panel near the three black "slots" and pull up. It will flip right off. Now you can see the SIM card. Place your fingernail on the edge of the metal that holds the SIM card and pull down gently. The SIM card will rotate open towards you and you'll be able to remove it. Pay attention how this happens so you can replace the card because it's too difficult to explain here. Good Luck!
How to install sim card in motorola
In order to provide correct directions we need the exact model of the phone.
Out older flip phones and early android phones require you to remove battery cover and battery. Our newer phones you open a SIM door on the side or top of the phone.
Mark
Motorola Support
May 07, 2014 | Motorola RAZR Cell Phones
Don't know what motorolo mobile I have it is a flip cover
Usually the model number can be found under the battery. Remove the back panel and pop out the battery. Look for a tag containing model number, serial number, etc. Pop the model number into Google and it will tell you the name of the phone.
Jan 07, 2012 | Motorola Cell Phones
How do i insert mymsim card on the i776 flip phone
With your phone powered off, remove the battery door and battery. Lift the rubber flap directly above the SIM card holder, and then with your fingernail, carefully slide the SIM card out (or in) under the edge.
Here is the manual.
http://support.sprint.com/global/pdf/user_guides/motorola/i776/i776_by_motorola_ug.pdf
Hope this helps!
Austin
Aug 04, 2011 | Motorola Computers & Internet
How do I install the sim card?
To install your sim card.
  1. Open the battery cover of the phone,
  2. Remove the battery of the phone,
  3. then you install the sim card in the direction that is shown on the silver panel under the battery.
  4. Reverse the process to cover the phone back, but do not uninstall the sim card.
take care
Jun 18, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I cannot get the sim card out of my motorola i730
Hello, please open this link: http://www.wonderhowto.com/how-to/video/how-to-operate-the-motorola-nextel-i730-mobile-phone-250239/view/
On that page click on SIM card Portability under Phone Feature...
If you are unable to remove the SIM card... then try to use a Tweezers.
Jul 14, 2009 | Motorola Mobility Naztech Nextel Iden...
How do I remove sims card from razr v3?
take the back of its under the battery
Jan 29, 2009 | Motorola Mobility RAZR V3
Simcard
changing sim card.............flip phone over....take back off...........take battery out.....take sim out replace it...put battery in..............cover back on done deal....
Nov 04, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility V66 Cellular Phone Logo
224 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
