Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Briggs engine starting problem
When I try to turn over/start my riding mower it is very difficult to the point where the starter will get hot and start smokin before it can turn over the engine sometimes I have to jump start it with the batterycharger to get it going, could you please tell me why this is.
  • 6,826 Answers
Maybe the connections to the battery are bad. The battery could be bad. The starter could be bad as the most likely cause.
The crankshaft could have too much resistance to mvoement.
Check these things out before calling a service center for your lawn tractor riding mower.
Posted on Jul 19, 2010
Testimonial: "Thanks I was tryin the cheapest route first but yeah I was hopin it wasn't but changed today and wammo fired up, thanks hun!"
Briggs & Stratton 331777-1372-B2 engine when trying to start , it is like the starter dragging, motor turns slow (like wanting to lock up) but may start and always runs great when it does start. Starter...
Need to adjust your valves.....they are a solid lifter system that comes out of adjustment from time to time. Its a complex matter and if not done properly can damage camshaft.
Sep 11, 2013 | Briggs & Stratton Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
LAWN MOWER WILL NOT START
The compression relief valve is not working. Pushing the engine past top dead center and turning the key works after a fashion. Keep the battery fully charged. This is a design/engineering fault in B&S engines which they cannot fix. It is in all of their engines. Most do not malfunction but those that do, do it all the time. I have had the compression relief valve replaced and the valve settings set to allow the valve to function (it uses the exhaust valve by holding it partially open while starting) but it still does not work properly.
Skip the below portion if you don't want to hear a negative view of B&S engines.
The engine problem resolved itself today (12-10-10) when it threw its rod into the cylinder wall. B&S engines power a huge number of the riding mowers in the US. It is difficult to escape them when buying a mower. Use it on more than a postage stamp yard and B&S will claim you abused it.
Jul 09, 2010 | Briggs & Stratton Briggs Stratton Intek V...
When i go to start the mower the turbine in the blower housing does not want to turn even though i can hear starter winding.i can assist the blower housing in turning by using my hand to get it to turn...
Blow the dust out with an air hose, If your starter is making an unusual whining noise and you can't hear the engine trying to turn over you may have sheared some teeth off of the gear on the end of the starter. r
Sep 03, 2009 | Briggs & Stratton Garden
Put battery cables on wrong
For starters remove the battery and take it back to the store where you bought it and have them test it. Your solution may be to purchase another battery.
Apr 21, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine drags while trying to start
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Jan 26, 2009 | Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
376 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
