Silent output Hi, I have the subject model which runs through a behringer u-control UCA200 USB interface so i can plug it straight into my laptop. The programme I'm using, cubase, picks up and records the sounds but wont play it back. Please help. I'm really stuck, i've tried loads of different ways. Thanks
    Problem Solver:
  • 10 Answers
Make SURE u have the right master out channel selected ur I/O, if its picking it up it has to come out.So look for the symbol I/O
Posted on Apr 22, 2008
Background noise on vocal track
There is no doubt that sound on PCs and laptops can be a pain, and I have had to run a mixer output through the mic socket before now, such is the insensitivity of the PC's inputs. But you have done this, which implies that the mic input is not being connected to the sound system. You should have some controls of the way the sound is connected - try the Control Panel (assuming you have Windows) and opening up the sound applet. You won't get anything through Audacity etc., until the system is delivering. Sorry I can't be more specific.
Dec 28, 2013 | Computers & Internet
How do i play tapes from sony lbt-xb60 to computer
You will need a "Y" cable: RCA male X2 to 1/8" stereo jack. Connect the RCA jacks to the Sony unit where it's marked "MD deck", and the 1/8" stereo jack to the "Microphone" input on your computer. If you are using a laptop, and don't have a "mic" input (1/8"), you will need to get a USB adapter like a Behringer UCA200 unit. That will actually be much easier in the long run.
Jan 15, 2013 | Audio Players & Recorders
Behringer No Input Signal
Mic level in the windows control might be muted or off. The sound functions are a control panel iterm Or in Macs it is a CDEV.
Also check to make sure the program has that input enabled as well.
and make sure you start out with fresh batteries, double check where you have things plugged in, so you are not plugged into the worng port plug on the computer
Feb 06, 2012 | Behringer Ucg102 Guitar To USB Interface
I bought the behringer UcA202 audio interface for acid music studio 8.0 The interface comes on but when I plug it in to the USB the audio doesn't enter the USB why won't it hear the audio through...
To hear audio through the USB, you have to go into your control panel and change the audio output to the Behringer interface. (It may be specific, or it may just have a generic "USB Audio" option.)
May 08, 2011 | HP Computers & Internet
I've recently purchased the NI USB Guitar Link, which comes with two Behringer discs. I'm having problems installing the Behringer iAXE (volume 3) software. Couple of things to share: 1. When I attempt...
If you get beyond the 32/64 issue, check the audio setup for your audio device in your windows control panel. If your USB interface both recieves from your guitar and sends audio to your external amp, make sure BOTH the input and output to the USB are listed as the in and out in the "VOICE" tab when you go to the control panel and "Sounds and Audio device properties".:
Nov 22, 2010 | Behringer VT250FX Virtube Guitar Combo...
Connection
first install driver, plug in usb port of your laptop
Apr 10, 2010 | Behringer (UCA202) Sound Card
Just purchased behringer u-control uca222. When first plugged in the power led came on. Downloaded the midi driver at the behringer site and attempted to install. Power led went out then the midi drivers...
The UCA222 is a USB AUDIO Interface, not MIDI.
You want to download the ASIO driver(s) and install those again. You then have to go to whatever audio software app you are using, and 'set up' the ASIO drivers within your audio software itself (read the manual or look at some of the headings under Preferences or Settings in the software window itself).
Also go to the Audio Settings panel and configure your Audio Ins / Outs, make sure they are selected and 'enabled'. You should see Behringer USB listed when you click on the audio out tab. Just click on it with the mouse button and release.
You also may have to go to the ASIO Control Panel (again from within whatever audio app you are using) and tweak whatever settings are there. Make sure the ASIO driver is selected (not the MS Win or Realtek or whatever), and check that the audio outputs are likewise enabled there.
(Some apps won't output any sound while you are adjusting the Control Panel settings etc, so you may have to adjust the settings, then close the panel, before you'll be able to test for audio output, then if it doesn't work, go back into the panel and adjust some more and try again.)
If you are trying to control a VST plugin or VST Instrument via MIDI, you just need to go into your audio app's Midi Settings panel and likewise make sure your Midi controller kbd (or other Midi source) is selected and enabled, and that the appropriate Midi channel is enabled (or you can just select Omni Mode and it will listen to all Midi channels).
Of course you must have some sort of MIDI interface to connect your keyboard to your computer. Many new kbds have USB in which case it will send/receive midi via USB (tho you may have to install the proper drivers for your specific keyboard first. - they will be on your install CD that came with the keyboard or available on the internet).
Good luck! Hope some of this helps.
Mar 19, 2010 | Behringer U-CONTROL UCA202 USB-Audio...
Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Jul 29, 2009 | Behringer B-1 Professional Microphone
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
How to use
the best way is to connect your master output to the uca200 input and uca out to your amp. u have to use a sound editing software to record.suggestions-audacity.
Yours DjNicq
Jul 21, 2008 | Behringer (UCA202) Sound Card
49 people viewed this question
 Grubhead
Grubhead
