Question about Refrigerators
We have an RS21 fridge freezer. Always freezing up. Last week, under the newly announced extended warranty (seen on Watchdog) it was 'fixed' again with some new parts. Fine for a week BUT Today it has stopped working altogether. Just warm inside. Freezer has totally defrosted and we've lost a lot of food! We turned it off at mains and on again.Nothing. Internal light still work but it is silent. No error message though. Can you help? Thanks Jeanne and david
  • 121 Answers
Time to check the defrost timer, these can go bad on defrost and warm up the freezer / or on run mode, and cause the freezer coils to frost up..it usually will cycle 2 or 3 times a day. If you can find the timer (bottom, near floor) it can be rotated to cycle. (there are about 5 wires connected to it (it's about the size of pack of cigarettes.)
Posted on Apr 21, 2008
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
Samsung sr s2026cvw problem FRIDGE FREEZER: This freezes in the bottom of the fridge, freezing my vegetables? What needs replacing? Comet came last March and replaced something in the back but I don't...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 21, 2010 | Refrigerators
SAMSUNG RS21 AMERICAN FRIDGE FREEZER SOUNDS LIKE A GENERATOR RATHER THAN A FRIDGE AND NOT SHOWING CORRECT TEMPERATURE ON READINGS. FOOD BARELY FROZEN AT TIMES BUT FRIDGE PART SEEMS OK. ANY IDEA'S?
Ring samsung up because this is a common fault in that make. I had the same problem, They should do something depending on when it was purchased ( 2005-2006 i think it was) it was on watchdog.
Nov 12, 2009 | Refrigerators
Samsung side by side fridge/ freezer model number RS21NGRS . Fridge side is not cooling . The fan was making a noise and has now stopped but the temp light is flashing how do i sort this problem thans.
Hi, there is a known fault with the Samsung RS21 units. If you unit is less than 5 years in luck, it is covered by the Extended warranty they have put in place. Apparantly this was featured on BBC watchdog!. i've had the same problem and had it fixed free of charge by Samung. Either raise a service request on the Samsung uk web site, www.samung.com/uk or call the customer services on 0845 7267864 and explain you description. the noise is an ice build up which stops the internal fan pushing cold air around the fridge. the bootom of the fridge , in the drawers is cold?
Aug 12, 2009 | Refrigerators
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Samsung refrigerator sr-l628ev ,refrigerator not working ,air mixing flow system notworking ,but freezer is working
I don't have a solution, but I have the same problem. Or rather I did until today when the freezer started defrosting itself too.
It sounds very similar to the RS21 problem that is on the watchdog website, but as my fridge/freezer is 8 years old I don't think they are going to give two hoots about repairing it foc.
Jul 27, 2008 | Samsung Refrigerators
Rs21/fcns fridge freezer fridge keeps icing up causing fan to jam on ice and water to freeze
I have a Samsung Side by Side Refridgerator RS21 FCNS which has stopped cooling the fridge - the temp sticks on about 14deg. Yellow pages engineer came out and quoted a ghastly job and £350.
Called Samsung on 0845 726 7864 and they told me that the defrost heater is a design fault and that warranty on this component has been extended to 5 years. Someone coming tomorrow to fix it (for free).
Apr 21, 2008 | Refrigerators
Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
