Question about Toyota SE-06 Mechanical Sewing Machine
I am trying to sew together some vinyl, I am using a standard sewing machine but with a leather standard needle and the correct thread. The machine keeps missing stitches and the stitching underneath keeps coming loose and puckering up. Do I need to use a heavy duty machine? an hire a specialist machine.
  • 340 Answers
I think you need to use a teflon foot (the white plastic one) when sewing vinyl. Hope this helps.
Posted on Aug 23, 2010
I am having trouble getting upholstery thread to stitch properly. I have the fabric set on leather/vinyl and am using a leather needle. Any suggestions?
Domestic machines are not set up to handle upholstery thread. For one thing, upholstery thread is much thicker than regular sewing thread, so the tensions will need to be adjusted (if possible). It is also very difficult to use heavy thread in the bobbin. Depending on the weight of the fabric you are sewing, you may be able to use a good quality polyester thread that is strong but not as thick as upholstery thread. You may also need to use a different presser foot and pressure adjustment for your project.
Nov 14, 2017 | Sewing Machines
Singer20u33 . I'm trying to sew vinyl and the tension is messed up . It was fine before on other fabrics
Vinyl is a very difficult fabric to sew because it is sticky and tends to grab the thread and hold on to it causing loops in the thread. It would help to use a roller foot or walking foot to help move the vinyl through the machine. Also, try using a very sharp leather needle or top stitch needle. Sew SLOWLY!
All About Needles
Oct 24, 2016 | Singer Sewing Machines
Singer 20 u33 machine . I'm trying to sew vinyl and the tension is not right . How do I adjust for sewing vinyl
Vinyl is difficult to sew because it tends to stick to the presser foot and the sewing machine surface. Try using a teflon-coated, roller foot, or walking foot to help with that. You may also want to try a sewing needle that has a larger scarf that will protect the thread when it penetrates the vinyl. Vinyl will tend to grab the thread and hold onto it when the needle withdraws from the fabric so you will end up with thread loops underneath.
You may want to try a leather needle or topstitch needle.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjt6KqX-trQAhVhiVQKHQCSAGkQFgguMAU&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Singer 401a. Sews material fine. Using a leather needle/machine goes thru material with ease but threads do not stitch together. Just pokes a row of holes. What needs to be adjusted??
Since I can't examine your machine, I'll give you some suggestions. You may find some of them obvious, but these are things I have found when repairing various machines.
First and most obvious, make sure the needle inserted correctly. The 401a uses a flat shank needle such as a 15x1, 130h/705. The shank needs to face to the rear with the groove in the shaft running all the way down the front of the needle to the eye. In backwards (yes, it is possible to do), it won't form a loop and the hook won't pick up the top thread.
Second, you will need to check both hook to needle timing and needle distance. You can visually check if the timing is close by turning the wheel until the needle is in the bottom of it's travel. Then raise it until the very front of the hook is behind the needle and not sticking out. The hook should be above the needle eye. If it isn't or very close, your timing is probably out.
The needle distance is the horizontal distance between the needle and the hook. The hook should be very close (usually .01mm).
With leather the loop may be smaller and the hook just can't catch it due to one of the above conditions.
Aug 11, 2015 | Singer Sewing Machines
Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
Aug 19, 2012 | Husqvarna Freesia 415
Kenmore sewing machine won't sew vinyl
There is several things you should use when stitching vinyl, treat it the same as leather. The main issue usually is getting the feed dogs to grip and move it through; this is why there are commercial grade machines specifically for leather hides and fur etc, it is tricky to stitch.
To stitch on a domestic machine, you need a leather needle with a spear tip to cut the leather so it doesn't split. Also, if you can get one, use a roller foot to roll over the fabric, or a teflon foot if you can't find a roller one. Also, use paper clips rather than pins to hold raw edges together (remove as they approach the foot and needle). You may also need to bash seams open after stitching (rubber mallet) and glue down the raw edges, this is how leather hides are stitched professionally. If you have to join more than 2 layers ie crossing seams, you'll probably need a Jeans-a-ma-jig device to help with feeding through the thickness and still getting feed. Like this http://www.punchwithjudy.com.au/shop/jean-a-ma-jig.html
You don't say what it is actually doing, ie stitches not catching, or the feed dogs not moving it through?
But if it is an entry level machine, it may not have sufficient engine power to pierce the vinyl, especially if the textile is thick. Also, don't try to use a heavier thread than normal weight, if you want the stitching to look heavier, then just run two reels of thread through all the thread guides, tension and the needle eye together. Something like buttonhole twist will be too heavy for the bobbin tension and top tension to handle.
Hope that this helps you with your project.
Dec 18, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
I am sewing outdoor fabric and using the strong thread and having problems with the bottom thread (bobbin), it is loose and sewing right. I have tried tightening the tension on the bobbin. It was sewing...
Probably a little heavy duty for a domestic machine - most don't like thread through the bobbin tension device any heavier than 50 grade.
Some tension devices have a hole that you can use to bypass the tension spring (Elna is one) which allows thread like perle cotton to be used in the bobbin. But you still can't put it through the needle (just on the underside for decorative sewing effects) .
In the past I've needed to sew vinyl tractor seats where I was stitching the vinyl to a 1/4" thick foam and after trying everything (roller foot, leather needle) on the domestic machine, I bought a Singer 20U industrial machine with 1 1/2 hp motor in a table in order to seam this weight of textile. Different system needle used and the bobbin could handle heavier weight thread.
Probably not the response you wanted though.
May 02, 2011 | Baby Lock Imagine
I am sewing on leather and I cant seem to get it adjusted right ? The thread gets all loose on the bottom and I am not sure I have it threaded correctly? It has been a long time since I have used my...
Have you lost your manual?
You can download one free from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 1620 and click on search.
Then choose any one of the three options on the next page by clicking free download!
I think for sewing leather or vinyl you need a very thick needle and a teflon foot (the white plastic kind). Tension settings are explained in the manual.
Hope this helps!
Sep 20, 2010 | White Sewing W1620 Mechanical Sewing...
Machine jamming
Hi! It's possible that the thread is too heavy, but there are other possibilities also. What size needle are you using? Is it a leather/vinyl needle? Also, it could be a tension problem, so try adjusting that on a scrap of the vinyl.
I found this bit about marine threads (http://www.seattlefabrics.com/thread.html). There are different sizes/weights of marine threads and it could be that you need to find a different marine thread.
Hope this helps!
Robbie
Apr 28, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
WHAT NEEDLES FOR SEWING LEATHER ON A LS 1217
The WEDGE POINT NEEDLE, which is designed for leather and vinyl, easily pierces these fabrics to make a hole that will close back upon itself. This eliminates unattractive holes in the garment, and also reduces the risk of the stitches tearing the fabric. The wedge point needle comes in sizes 11 to 18. The size 11 needle is designed for soft pliable leathers,while size 18 is designed for heavy or multiple layers of leather or vinyl.
Feb 08, 2009 | Brother LS-1217 Mechanical Sewing Machine
Toyota SE-06 Mechanical Sewing Machine Logo
187 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
