Question about HP LaserJet 1000 Printer
My hp 1000 series prints well but as soon as a paper is feed in wrongly and the printout comes out folded it detects a paper jam error, while in reality the printer doesnt have a papar jam. which part of a printer detects papare jams?
  • 1,218 Answers
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
Posted on Oct 14, 2010
  • HP Master
  • 6,826 Answers
OK, there's either an optic sensor or a physical switch that determines that paper is in a spot that it should not be on printers.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01489959&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Jul 19, 2010
  • dfwsw fdfw fgdgfegsd Feb 28, 2011
    In my case, relay switch act as gear break is malfunction. Relay switch located at the right side of printer. Check it. After rearranging, my printer works well.
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Officejet 6210
Hi, I can help you with your printer problem. Please open this document and follow the instructions to the letter. http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=fi&cc=fi&dlc=fi&product=12019&docname=c00249509 Let me know how it goes. Good Luck
Sep 17, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
234 people viewed this question
Ben Johnson
