Question about Air Tools & Compressors
I have lost my manual for a Challenge JR5979 battery charger which will not work Any ideas
SOURCE: Radio works off battery but charger does not work
I cam working on one and the transformers' primary winding is open. You will most likely need part # 429790-48 from Dewalt.
Posted on Feb 13, 2008
SOURCE: vivitar dvr550 battery charger
Try Sunny Technology Co Inc
Model SYS 1193 1005 W2
It appears to be a universal cell phone charger.
Hope this helps.
Posted on Dec 07, 2008
  • 303 Answers
SOURCE: lost battery charger need new one
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL805
Posted on Mar 04, 2009
SOURCE: I lost my battery charger and i need to charge my camera battery
I lost mine too and did a search on ebay found one from hong kong that worked just fine it was cheap too! just search ebay.
Posted on Apr 10, 2009
  • 672 Answers
SOURCE: NEED A MANUAL FOR A RYOBI BATTERY CHARGER
This link should help in finding a manual. Good luck. http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_battery_charger_product_list.html
Posted on Jul 04, 2009
Battery charger for Challenge drill
http://argos.scene7.com/is/content/Argos/2580580_R_D001pdf
Here is the customer helpline for this product:
0345 640 0800
Thereer is an 18V charger for another Challenger Extreme drill but I do not know about its use with your designated drill. I notice in the documentation 2 x 1.2 Ah Ni-Cd battery back
-1 x 3-5h charger
Here is a smart charger which is 3-5h:
It shuts off when the batteries are charged.
http://www.uniross.com/products/3-5h-lcd-charger
May 30, 2017 | Miscellaneous
Hitachi cordless drill charger not working
The various rates of flashing are error indicator codes and should be explained on the charger case. They are for the condition of the battery's though and not the charger. It sounds like the charger itself is bad. Can you return it for a replacement? Is it still in Warranty? For whats its worth, I went from Milwaukee tools to Bosch to De Walt before being satisfied with performance. I hope this helps.
Dec 14, 2013 | Hitachi UC18YRL Universal Charger for...
Battrey charger not working
change you battery charger
Jan 18, 2012 | Drills
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
I need a charger for my Samsung WB600. I somehow lost it. Still have the USB cable. Any suggestions?
The Samsung WB600 digital camera is also known as the Samsung HZ30W. (see the Samsung Product page.for accessories, manual, etc.)
pchpatti_5.pngpchpatti_6.png It uses the Samsung SLB11A Lithium Ion rechargeable battery. Several third-party compatiable chargers for this battery are available through retailers such as Amazon.com:
Add shipping costs for each.
An extra battery is usually a good idea, too.
Jan 22, 2011 | Cameras
How do you recharge a Motorola sp10 I need to know how to recharge it. I lost the manual.
There are three methods of charging the HNN9044 battery used in an SP10 radio:
1) Use the HTN8232 10-hour wall charger. It plugs into a jack under the flap on the side of the radio (opposite side from the PTT button).
2) Use the drop-in style charger by setting the radio in the charger (this works if your radio has silver battery contact showing on the bottom.)
3) Use the drop-in charger to charge the battery alone. (The battery will set in the charge crossways to the way a radio would set.)
Lastly, if your battery will not charge by one of the above methods it might need replaced.
Best regards.
Nov 14, 2009 | Radio Communications
Homelite trimer 18.0v charger, battery, yellow
homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
Sep 12, 2009 | Homelite Garden
Battery charge
Did you cleaning the contacts on charger, If so then go to a camera store with your battery and charger and try there battery in your charger, Then you can narrow down the problem, I think your charger is bad. TC
Dec 06, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Charging the battery on Jazz HDV178 digital camcorder
Use the charger that came with it and insert the mini-USB plug into the camera. The red LED will flash until the battery is charged and then it will stay on steady. I left mine overnight the first time. About four hours the second time. Still don't know exactly how long it takes though.
Jun 12, 2008 | Pentax Optio A10 Digital Camera
Air Tools & Compressors Logo
300 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
