Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Jets may be clogged Canon 6550
IS it easy to fix or do I need an expert?
  • srm1 Apr 21, 2008
    The Canon MF 6550 does not have jets, it is a laser printer/copier
    Genius:
  • 1,665 Answers
A method may be referred at user manual. I have not download it. Download from given link (retrevo...).If not post a new message.
Posted on Apr 21, 2008
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon imageclass MF 6550
Try printing a test page. Is it also blank? If so, you should check your ink system (cartridges full, etc.)
Apr 21, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Won't print...says it is printing but doesn't
printer has just been left unused for some time? You probably just have an ink clog.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the MagicInkjet Flush kit to soak the print head and you should be printing again like new.
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 23, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
My canon pixma ip1980, does not work the power ON, the cartridges were fine( they are new). please help me.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the print head?
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Got a new computer and the printer may not be set up correctly its not working
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog?
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart C5180 All-In-One InkJet...
After cleaning the nozzles, the quality of print is still very poor. What should we do?
HTML clipboard HTML clipboardHi
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Canon Office Equipment & Supplies
Canon pixma 3000 won't print red
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the magenta *red.
But provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Good Luck!
Tinteiros (Ebay)
Oct 28, 2009 | Epson Stylus C86 InkJet Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
Lost manual need help with paper settings
Go to My Computer, next Control Panel and then Printers. Right click on the printer and go to "Printing preferences" You can change it there.
Mar 13, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
