Question about Frigidaire FTF2140F Front Load Washer
Model FTF2140FS0- All display lights illuminate and signal beeping occurs . This happened after we washed a small load and the machine became out of balance.
5 Suggested Answers
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
  • 236 Answers
SOURCE: door lock indicator will not illuminate- washer will not run
you may have a faulty door interlock?
Posted on Feb 17, 2008
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
caroldon
  • 17130 Answers
SOURCE: during the spin cycle the
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Posted on Sep 16, 2010
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
How come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Apr 27, 2014 | Bosch Washing Machines
I have an F&P top-loading machine, about 3 years old. There is no model number on the machine fascia. The problem occurs after startup. It starts to fill with water and then it beeps. There are two...
Hi Grant, just read your posting.The model number is on a sticker at the back of the machine, top left.Now the lights that come on when it is beeping will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine beeps,Is it the 2nd and 5th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 05, 2010 | Fisher and Paykel Washing Machines
My fisher and paykel WG708 top load washer fills with water. No rotation of the washer occurs. No machanical sound happens. 4 lights stay on and makes beeping noise. Water will drain but no spin happens?
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 06, 2010 | Fisher and Paykel Washing Machines
I have a GWL11 Fisher Paykel washer. It was running fine then it was beeping and had stopped-- the spin light was the only one left on, although water is in it. Basin looks lower than I recall. It won't...
Hi just read you posting.Now when the machine was beeping was the spin light the only light that was on while it was beeping?If this is the case then my manual tells me your Motor Controller is faulty and needs replacing.Please confirm which light was on when the machine was beeping because the motor controller module is not cheap.Looking forward to your reply.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Electrolux 1087 E90
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF2140F Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
