Question about Sharp R-1480 Microwave Oven
Sharp Microwave Oven
Since having a power cut, I have been unable to reset the clock on my Sharp microwave oven.
The model number is R 246
Shayna
  • 64 Answers
SOURCE: Sharp R-9H56 Microwave convection oven
Typically in a microwave, you get into programming mode (sounds like the auto/clock button is doing that) set the time and then press START. Give that a try.
Posted on Jun 08, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have lost instruction book
Normally you press one of these combinations:
CLOCK > 1 > 2 > 3 CLOCK
CLOCK > 1 > 2 > 3 START
CLEAR > CLOCK > 1 > 2 > 3 CLOCK
CLEAR > CLOCK > 1 > 2 > 3 START
Posted on Aug 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Posted on Feb 02, 2010
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
User manual for a model R-209 AK counter top carousel microwave
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Top Automotive Device Types ..... Sharp M I C R O WAV E O V E N OPERATION MANUAL. Pages: 0 ... Sharp Microwave Oven 209H ... SharpOperation Manual Microwave Oven R-308H, R-305H .... Sharp Microwave OvenMODEL R-2197 ... Sharp over the counter microwave oven operation manual ...
SHARP MICROWAVE OVEN Parts ' Model r209ak ' Sears ...
www.searspartsdirect.com/model-number/r209ak/0958/0123245.html
Shop for SHARP MICROWAVE OVEN repair parts for model r209ak at Sears ... Find part in diagram SHARP Countertop Microwave Model # R-209AK.
Jan 07, 2016 | Sharp Microwave Ovens
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
I have a sharp carousel microwave model r-120D. It is flashing all 8's like so 88:88 and i cant get it to reset or work at all. Can you help?
usually does this after power outage. reset the clock. go to sharpusa.com and select PRODUCT DOWNLOADS under the CUSTOMER SUPPORT menu...select product not listed in drop down list, then enter R120PK in box....this should be the manual for your microwave
Dec 10, 2010 | Sharp R-120D Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
The door on my Sharp Carousel II Microwave Oven will not open. The display says LOCK. Looking at my booklet revealed that there is a safety lock feature. I tried to cancel by touching Autostart/clock,...
Sounds like a drawer type microwave or a combo oven and microwave?
If your manual's instructions didn't fix it, you can try a hard reset.
Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you still need help, please reply back with your model number so we can help you.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Sharp Microwave Ovens
Sharp Carousel Microwave R-320FQ Serial # 26805 Mfg. Dec. 2002
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
It may have an intermittently shorting keypad or another problem on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
Jun 08, 2008 | Sharp R-1480 Microwave Oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
