Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The Machine is flashing a F1 fault code the manual say's to turn off power and water supply and ring service centre. Is there a code sequence to get it back to start.
  • Fisher and P... Master
  • 3,247 Answers
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Posted on Jul 30, 2010
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
Why does a fisher and paykel DD-603 randomly gives f1 code even when not in use
Fault code F1 can come from a number of different sources and can remain on as long as the machine has power (does not need to be operating). Once a fault is repaired it can be cleared by pressing the Power button. If the fault is still present then it will not
clear. The service manual says: The faults are displayed in the LCD as one of 5 F (fatal) faults or 1 U (user) fault along with the symbol of a spanner. A fatal fault will usually require the assistance of a qualified service person...
Fault Code Description:
Fault Code: F1
LED Display: Rinse LED
Fault: The flood switch has been activated for more than six seconds
Possible Causes
_ Inlet hose to inlet valve connection loose
_ Inlet valve body leak
_ Damage to the fill or drain hoses
_ Heater plate damage (chipped enamel)
_ Seals/O Rings (pinched, contaminated or poor join)
_ Dispenser (seal, diverter valve or weld leak)
_ Lid area (lid motors not functioning correctly, lid off yoke or foreign object interfering with lid seal)
Fault Code Problem Solving:
    1.Question: Is there a F1 on both displays? Yes: Go to Question 2. No: If power fails to the bottom tub it will cause thetop tub to go F1. Test heater plate.
    2.Question: Has a flood occurred? (N.B. The flood may have dried up) Yes: Go to Question 3. No: Go to Question 13
    3.Is the lid sealing on the tub correctly? Yes: Go to Question 5. No: Go to Question 4
    4.Question: Are the lid actuators functioning correctly? Yes: Go to Question 5. No: Check the lid actuators are assembled correctly on the slides and yokes. Check the plugs on the RFI board and the terminals on the lid motors. If the lid actuators look slow replace them.
    5.Question: Is the water level in the tub high? Yes: Go to Question 6. No: Go to Question 8
    6.Question: Is the water inlet valve leaking? Yes: Replace inlet valve. No: Go to Question 7
    7.Question: Is the DishDrawer priming correctly? Yes: Go to Question 12. Go to Question 8
    8.Question: Is the spray arm split? Yes: Replace spray arm. No: Go to Question 9
    9.Question: Is the spray arm running freely? Yes: Go to Question 10. No: Check the rotor is running freely, clear of foreign objects and fitted correctly. Make sure the wash impeller is not slipping off the rotor shaft.
    10.Question: Is water leaking from a split inlet or drain hose? Yes: Replace split inlet or drain hose. No: Go to Question 11
    11.Question: Is water leaking around the heater plate 'O' rings? Yes: Replace or refit 'O' rings. No: Go to Question 12
    12.Question: Is the drain hose blocked? Yes: Clear drain hose of blockage. No:Go to Question 13
    13.Question: Is there condensation or foreign matter around the flood switch PCB? Yes: Clear flood sensor of condensation or foreign matter. No: Go to Question 14
    14.After clearing water does the F1 fault code still activate? Yes: Replace Chassis RFI board. No: Go to Question 15
    15.Refer to Bulletin DW028 DW025, 028, 031, 040
Sep 06, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
My kenmore keeps getting f1 code had it fixed and it cost almost 400 dollars and it is doing it again washer was just over a year old when this happened,gave 1200 for washer should last 10 years with out...
This problem has been found to be inherent with this model including its Whirlpool (Cabrio) and Maytag (Bravos) counterparts. It is due to the design of the water level control system, the pressure transducer, which has been integrated with the machine/motor control assembly. It has been found that issues with the pressure transducer including the pressure hose results in the flashing of the fault code F1. Air leaks and moisture in the pressure hose and lint or flashing in the air dome can result in signal error being sent to the machine/motor control assembly and hence the fault code F1 which is according to the service manual, a machine/motor control fault. You may observe that this fault code appears whenever water runs into the machine.
Whirlpool, the manufacturer of these models, has issued a bulletin regarding this issue and suggested the necessary actions in identifying the real cause of this problem and how to address it. Click on the link below for the troubleshooting and repair details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Machine goes through the wash cycle then stops before it rinses and spins . Machine displays F1 OR F5 which indicates an error has occured , have to empty manually but cant get it to spin at all .....
Hello
F1 is usually a low water code.Check your hoses and water supply inlet screen for any bulid up of dirt or sediment.
Also the water inlet valve may need to be replaced.
F5 is a water temp fault.Possible bad heating element or thermostat.
The F1 code could be causing the F5.
Due to low water.
May 04, 2011 | Indesit Washing Machines
F1 error
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jul 12, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
83 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
