My ibook a1005 powers on, but the screen wont display nothing. stays dark. Please help
  • 6,993 Answers
the fault might be from the screen flex or screen inverter.
To confirm this, connect your ibook a1005 to an external monitor and if there is a display, then the screen inverter or flex is the cause of the problem and it needs to be replaced for there to be a display on your ibook a1005 screen.
But if there is no display when you connect the ibook a1005 to an external monitor, please let me know.
Take care.
Posted on Jul 19, 2010
  • beautifulgal Jul 19, 2010
    walesarumi suggested that I should connect my ibook a1005 to external monitor inorder to trouble shoot why my ibook A1005 screen wont display, i dont know how to connect it to external monitor. I didnt see any connection port to do that. Please, kindly explain step by step on how to connect ibook A1005 to external monitor. Please help.
  • Walesarumi
    Walesarumi Jul 19, 2010
    follow the steps in the apple link and find out the type of cord that will be needed. And also the steps how to do the connections:
    If you don't have the VGA cord, you can borrow it from a friend.
    http://support.apple.com/kb/TA26429?view...
    Good luck.
How do I factory reset my ibook A1005 G3
Volume down button+power until screen flashes release when boot loader screen pops up ( black screen with cammand prompt) use volume up and down keys to navigate .....Scroll down till reset system is highlighted and use the power button to select and system should reset from there.
Feb 10, 2017 | Computers & Internet
My ibook laptop model A1005 is not turning on what can i do to fix it
You can try this link to see if it helps ... if not take your iBook to your closest Apple Store and book an appointment to a Genius (beware the Soooper Genius) ...
http://support.apple.com/kb/HT1431?viewlocale=en_US&locale=en_US
K
May 11, 2014 | Computers & Internet
Check your power supply. Test it if you can. If not, borrow a good one and try it.
Need manual for Apple iBook G3 12" 800MHz model no A1005
You might want to try this? I am not sure if it is the same as your machine.
http://manuals.info.apple.com/en_US/PowerBook_G3_Users_Manual.pdf
Try this page and keep looking in this area if the one above is not the same model.
http://support.apple.com/manuals/#G3%2012"%20user%20manual
Good luck hope this helps.
Jan 15, 2013 | Apple iBook G3 800MHz 256mb 15GB CD Drive...
Ibook a1005 won't start .My daughter had a ipod touch from China plugged in- it shut off and won't attemt to start.The battery is full and has a new power cord.Is there a reset somewhere?
Ok, there is something you can do to try to fix this. You need to reset the power management circuits - it's very simple, just follow these instructions:
  1. Firstly, try a less drastic approach - hold down the power button for 5-10 seconds. This may succeed in starting up your iBook.
  2. If that doesn't work, you need to reset the power management. Unfortunately, there are plenty of different models of iBook and many have different ways of resetting. You'll need to consult this guide to decide which way will work for your model.
If you need a hand figuring out what type iBook you have, just ask, and I can guide you through figuring it out. Same goes if you don't understand some of the instructions.
Hope that helped, good luck!
Dec 28, 2010 | Apple iBook Mac Notebook
My Ibook A1005 (2002) model,just wont boot up,I press the power on button,the Apple sign comes up,and it just continues to load with no results!!!!It was working just fine,can anyone assist me
If your iBook loads to the Apple logo with a spinning gear beneath it but does not progress past that point, follow the instructions in the following article to attempt to resolve the issue:
http://support.apple.com/kb/TS2570
May 18, 2010 | Apple Computers & Internet
A1005 Battery and power supply fine - but not starting
A1005 is an inexact marketing identifier covering pretty much the entire line of G3 iBooks.
Complete failure to start -- unless it is caused by something trivial like a broken start button -- without any startup or error tones, points to basic logic board failure. A machine this stone dead for no apparent reason is unlikely to be revived, and almost certainly not by third-world techs who don't know Macs. It is debatably cost-effective to resuscitate a sub-GHz G3 iBook from such a failure, compared to replacing the unit with another new or used Mac. The drive in the old Mac can be extracted so as to preserve your data, and can be inserted into an external USB or FireWire case to be accessible to a new Mac.
Oct 10, 2009 | Apple iBook Mac Notebook
Ibook display problem
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Oct 07, 2009 | Apple iBook G4 Mac Notebook
I-BOOK A1005 bootup problem
if its a pale blue screen with a really old looking graphic of an apple logo then that means it is not finding a bootable device
Jul 02, 2009 | Apple iBook Mac Notebook
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
