Question about LG Art Cool LA121HNP Split System Air Conditioner
CH61 LG AC not working
LG AC not working. Fault code CH61 showing. What does this mean?
Not cooling
Posted on Jan 06, 2011
    New Friend:
I have floor stand unit lg model number tp-c1008fao,indoor showing error ch 61 what is solution
Posted on Jul 14, 2013
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
DialFix - AC Repair ' Refrigerator Repair ' Other Appliance Service ...
www.dialfix.in/
AC Repair ' Refrigerator Repair ' Other Appliance Service Center in Hyderabad
Posted on Jul 23, 2016
    Sergeant:
    Habit-Forming:
  • 113 Answers
Just Dial dialfix they will help you with all things. http://www.dialfix.in/lg-ac-repairs-services-in-hyderabad
Posted on Mar 17, 2016
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
I have a lg titan inverter 9000 and it won't work because of error ch61. What does it mean? How can I solve it?
It normally means that the external unit is overheating,but if the unit doesn't work at all then it sounds strange, i would advise in both cases to get the technical service center in to check it out, if you have a gas leak , it will run a while then stop, but if you havent got the gear to check it out get the service center in.
Dec 13, 2014 | Heating & Cooling
Solution of code Error Ch-10 in LG AC
LG canceled inverter AC ch10 error
Jun 03, 2013 | Heating & Cooling
My air conditioner has just stopped working with error code CH61 what does this mean?
Not enough air being drawn over the outside condenser unit. This could be for a number of reasons. The unit may be covered, restricted, or blocked. The condensor fan may be inoperable on the unit. Without a model number I would first check the outdoor fan for proper operation, and contactor and run capacitor. It sounds as though the compressor is coming on and going into thermal overload.
Feb 13, 2011 | LG Heating & Cooling
Hi, I ve got a aircon LSZ244VM4 inverter and fault code is CH 61.Iam out of warranty 1 yr and the unit has already been replaced 1 time when it was in warranty.So what should i do now and what does CH61...
Ch-61.Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condesables
Clean coil & filter. If non condensable gas, remove gas and flush out the system. Vacuum and recharge.
Jan 01, 2011 | LG Heating & Cooling
I have a "cl"or "c1"
C 1 means indoor thermostat sensor defective.
Dec 11, 2010 | LG LA185HV Split System Air Conditioner
My LG Artcool isn't working keeps flashin ch 61
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. kHnce remove the gas, flush out the system and vacumize and then do gas charging.
Dec 10, 2010 | LG Heating & Cooling
LG Reverse cycle ducted (in ceiling) airconditioning works normally on heating and coooling and then cuts out after 2 days and shows error code 61.This is in 3rd floor apartment. The system can be reset by...
Error code CH61 - CONDENSER PIPE HIGH PRESSURE. This can be due to overcharging of the system or the condenser clogged with dust or an obstruction, or condenser fanmotor not working. Hope this helps.
Nov 16, 2009 | LG Art Cool LA121CNP wall/window Air...
LG Art Cool LA121HNP Split System Air Conditioner Logo
2,751 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
