Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Harddisk woun't mount
LaCie Neil Poulton 1TB USB/eSata/Firewire will not mount, not with USB cable, not with eSata. In the device manager I can see it, however. What to do?
  • 11,800 Answers
The hard disk inside it has probably died. Take it out of the case and put it in the pc directly - if even now it's not responsive then it's surely dead - junk it. if now you can see it then the electronics if the case are dead - junk it and buy a new external case.
Posted on Jul 19, 2010
My computer is not recognizing my hard drive.
You will need data recovery help. This guy does it remotely and works off of donations. FreeDataRecovery.us
Jul 12, 2011 | LaCie Hard Disk design by Neil Poulton...
I dont see the drive in my computer
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 28, 2011 | LaCie Hard Disk design by Neil Poulton...
I have a lacie 500gig external hard disc and i fail the optimization and the disc shows only 9.9mb and i formatted in hope that will have the same setup assistant -but i turn wrong.Please tell me a...
click start control panel administrive tools computer management scroll to disk drives if you can see your drive right click select properties tools tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box then wait for that to finish
also + to expand right click you should see options update driver disable uninstall scan for hardware changes
hope this helps
May 06, 2011 | LaCie Hard Disk design by Neil Poulton...
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
My Lacie 1T hard drive tells me it has insufficien memory when I try to add a file it is brand new how do I reformat it?
Have you followed the steps given below accurately ? If not, do it once again please
1. Connect the power supply.
2. Connect the USB, FireWire or eSATA cable to your computer and to the drive.
3. Turn on the drive by moving the power switch to On or Auto (drive powers on/hibernates automatically). The drive will mount in My Computer (Windows) or on your desktop (Mac).
4. Before using the drive, LaCie Setup Assistant software must be launched to format your drive. It will
• Optimize your drive according toyour needs
• Copy the manual and utilities on
your drive
I Hope this is helpful
Nov 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Lacie 1tb ext hd. drive does not show in disk
Your external drive has 2 parts, the hard drive, which is just a normal hard drive you would find in any computer, and the usb bridge, which connects the hard drive interface (either ide or usb) to the usb or firewire or esata or whatever. Sounds like one of these are bad. Does the computer see the bridge? it should show up as a mass storage device in device manager and the safely remove usb devices dialog. If not, then get a new enclosure for the drive. These range from 25-100 dollars. If the bridge does show up, take apart the enclosure and pull the drive out and try hooking it up as a second drive in your computer. If it works there, then you need a new enclosure. If not, then you need a new drive.
Dec 07, 2009 | LaCie Computers & Internet
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
806 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
