Question about Sony XM-1S Car Amp
HELP Hi i need help with my amp it is a SONY XM1S SMALL CHASSIS MONO AMP 900 WATTS can i run a 1000w sub and a 190w pair of speckers of it THANKS
  • 70 Answers
No you can't cause 1 of 2 things will happen you might damage the speakers or sub, or 2 you will blow the amp or the fuses. if you blow the fuses then it will be constantly blowing and you will spend a lot more money than just buying another amp.
Posted on Jul 28, 2010
How would you hook a alpine r12 dual 4 ohm sub to sony xm-1s mono amp
in parallel get both positives and both negatives together and wiring them to amp for a 2 ohm load. the sony xm1s is a 2 ohm mono amp
Dec 31, 2009 | Car Audio & Video
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
AMP FOR MY SONY SUBBS
Get an amplifier that is rated just under the power ratings of the subs, that way you will not blow the subs by pumping in too much power to them. An example is, if you have 2 subs that are 500 watts each and you are going to connect them in stereo mode, you need an amp that is no more than about 400 to 450 watts per channel. This will push them very hard, but will not blow them by overdriving them. If you are going to connect 2 subs at 500 watts each in a bridged mode (in parallel across both channels) then you need an amplifier that is about 800 to 900 watts total power for both channels. This is basically the same power ratings for an amp, but some amps are mono (just one channel) and will have just a total power rating, while other amps are 2 or 4 channel amplifiers and have a rating for each channel.
I hope this helps in your decision making, if you need more help let me know. I have been repairing car audio equipment for almost 20 years and have seen just about everything.
Dave
Jan 16, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Jun 21, 2008 | Sony XM-754HX Car Audio Amplifier
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Sony XM-1S Car Amp Logo
41 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
