Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Terminology What is a Main PWB? Also, what is ETI 170535 and the V34 Modem? Thanks!
    President:
  • 2,072 Answers
The main board is the processor in the fax machine, Sorry the ETI number is just a reference to an engeneering note and V34, it pretty much the standard modem put in a fax machine, it is adjustable at I think the speeds are 9600 baud,14,4. 28.8 and 33 k. Also it can run in a mode called G3 which I am not really sure of.
It's a pretty versitle modem used in most faxes.
I am sorry, I sent the information directly from the technical tips.
Should have specified, but when time is short, sadly as many people do I took a shortcut.
If you have any other questions here is my e-mail.
rkasper@hughesxerographic.com
Ask away..will be glad to help.
Posted on Apr 22, 2008
I HAVE AN ECOSYS FS- 6525MFP KYOCERA COPIER PRINTER. IT DISPLAYS ERROR CODE F000 WHAT CAN I DO TO RESOLVE THE PROBLEM?
Code
F000
Description
Main PWB - operation panel PWB communication error
Causes
Defective main PWB.
Defective operation panel PWB
PWB = printed write board
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=FS6525MFP&code=F000
Nov 07, 2017 | Kyocera Office Equipment & Supplies
Kyocera Mita c610 error
C0610 Bitmap (DIMM) problem
There is a problem with the data or
address bus of the bitmap DRAM.
Defective main
PWB.
Replace the main PWB and check for correct
operation.
DIMM installed
incorrectly.
Check if the DIMM is inserted into the socket
on the main PWB correctly.
Defective DIMM. Replace the DIMM and check for correct
operation.
Dec 15, 2014 | Kyocera Office Equipment & Supplies
Replacing a DC controller board
When replacing DC/main PWB or engine board, be sure to remove the EEPROM from DC, main PWB or engine board that has been removed and then re-attach it to the new DC/main PWB or Engine PWB, cheers
Jun 06, 2014 | Kyocera Mita KM-5035 Printer
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
Kyocera fs 9530 - f040 error
this error came because of the Defective harness between engine PWB and main PWB or improper connector insertion. open both board and re fix it and check ....... please mention your correct printer model in next comment so we will give you idea how to open the boards ....... restart your printer and check it ...........
Main - Engine controller PWBs communication
error
• The communication breakdown occurred
between main controller PWB
and engine controller PWB during 30
seconds.
cause
Defective engine controller PWB........Defective main controller PWB.
solution
Replace the engine controller PWB
Replace the main controller PWB
Dec 21, 2009 | Kyocera FS-2000D Laser Printer
ETI Camcorder
its because you don't have the player for 3gp, install any nokia pc suite and player, or 321encoder
Dec 13, 2008 | Nokia 6600
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
Cannot Send Faxes
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Apr 16, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
MODEM DRIVERS
I DO NOT KNOW IF THIS WILL HELP BUT I WILL GIVE YOU ALL THE INFO I GOT OFF MY PC ABOUT THE MODEM
MANUFACTUER - CIRRUS LOGIC
CIRRUS LOGIC 33600 bps PnP V34
DRIVER VERSION 5.1.2535.0
IM SORRY BUT THAT IS ALL I CAN GIVE YOU
THANKS
Jan 12, 2008 | Computers & Internet
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
52 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
