Question about Intel D945GCL Motherboard
My cpu all fuctions is running but monitor is not getting display, i checked each part of cpu but problem is same. i checked monitor also .another machine but monitor is ok. please slove my problem. regards raja
  • Intel Master
  • 11,800 Answers
Have you tried to use a separate video card? Maybe the video chip from your motherboard has died ? If you have tried that and it didn't work then the motherboard is dead, junk it and get a new one.
Posted on Jul 19, 2010
Ma cpu shows it is ok, I mean motherboard is running but the monitor remains black....monitor shows it is unplugged while I unplagged the wire connect agp with monitor...But when it is connected it just...
hi!
if your cpu system is okey and there is no display in your monitor, try another monitor and if still no display check you video card, if so replace it with external video card.
thanks!!!
hope it helps!!!!
Nov 10, 2010 | Intel D845GVSR Motherboard
The CPU is running and all devices working too but cannot display to monitor. I also change monitor for testing, but still cannot.
What's the CPU running?  Did nothing ever display on the monitor since you powered up?  In that case, your display adapter (a.k.a. videocard) is looking suspect; maybe its output transistors got blown.  Find a slot for video and put a card in there and try again....
May 18, 2010 | NEC PowerMate eco PC Desktop
When i run cpu but monitor display donot showing
I assume you have already try it with other PC and get the same problem.
Next step will be taking it apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further, it will also help out other people with the same problem.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 05, 2010 | Samsung 933SN Monitor
Monitor will not power on. All of the connections
yes all the connection are intact, in these cases have the cpu check the monitor is not the problem, the monitor is still displaying which means that it is good, have the cpu check or check how many vga adpater is present in the cpu, if you have a built in and a separate card and you plug the monitor to the built it will not work and you need to connect it on the separate expansion card that is install inside your cpu
michael
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
V7 - S20PD TFT Monitor - Display goes off after about an hour
Hello, I am sure that you have some software settings problem. go to - DISPLAY PROPERTIES - SCREEN SAVER - MONITOR POWER. There select NEVER TURN OFF monitor. Your problem will be solved. BYE
Oct 10, 2009 | Computers & Internet
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Noggin
no run sistem? well if you talking about OS.or nothing display on monitor but the cpu work, check the conecction between monitor and parallel conector on cpu, video card,cpu fan. power supply.
those are critical parts.
Nov 18, 2007 | Intel Motherboard
Intel D945GCL Motherboard Logo
169 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
