Question about Dell Inspiron 1525 Notebook
My computer does not charge when on charge display the word "plugin in not charging"
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
Er this is the dell old problem.
Follow the below steps to fix it.
The Battery didn’t charge or detect being plugged in also caused by four reasons:
  • 1. The Vostro 1510 laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell motherboard problem
  • 4. The laptop bios is too old to recognize the battery
View more here : http://www.laptops-battery.co.uk/blog/battery-plugged-in-not-charging-solution/
Posted on Aug 03, 2010
2 Suggested Answers
  • 30 Answers
SOURCE: whenever i plugin my lappy for recharging my syste...
To resolve this issue, download and install the latest BIOS Update for your notebook from the manufacturer site. Later perform the following steps:
Power Management reinstall:
1. Click Start, type "device manager" in search tab.
2. Locate device manager from search list and pen it.
3. Click "+" beside System devices.
4. Select ACPI Fixed Feature Button.
5. Right-click the device and select Uninstall.
6. Restart the system.
Posted on May 26, 2010
I am trying to charge my Garmin GPS on my computer, but it only shows me a plugin at the bottom what is wrong?
That's normal. The connection is meant for putting new software into the Garmin. It probably charges at the same time, but there's no indication of the state of charge.
Oct 14, 2014 | Garmin nuvi GPS
LAPTOP NOT CHARGING
With Dell you have to use Dell OEM chargers to keep all the functions. Like charging and use at the same time. Otherwise it wont do both. Look on Ebay for a genuine Dell charger or go to Dells website. Be advised that it might be the jack on the computer though.
Apr 28, 2014 | Dell Inspiron Computers & Internet
Traveltek sx 1068
I have a traveltek tablet10.1 capacitive multi-touch screen android jelly bean 4.2.2 1.0 tnx processor & 1 gb ram I can't get it to come on at all even with charger is there a light to show it's charging cause it hasn't been on for months so what do I do please help
Apr 13, 2014 | Computers & Internet
Broke power plug plugin boaed
Take it to a repair shop. You will never get a replacement board for this.
Apr 13, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
I have got problem in my laptop, the battery is not charging, it indicates plugin not charging. i need your help
Hi
Your laptop in warranty then go to the seller and replace the battery, otherwise go to the dell vostro and bring the new battery.
Jun 22, 2011 | Dell Vostro 1220 Laptop Computer PC...
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
My computer will not charge and itunes will not play
Hi. I would suggest to powerdrain your laptop and try to charge it after the powerdrain. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac is out. After that place back the battery and plugin the ac adapter and turn on your computer and see if its charging or not. Regarding your problem about the ITUNES software you could try uninstalling first the itunes and then download the latest version from google and install it on your computer. Hope this helps
May 13, 2010 | Lenovo 3000 C200 Notebook
When i plugin chargar mobile show usb connect
Insert your charger pin completely into the phone. Then phone will show charging now.
After also if problem not clear then you have to reset the seetings and try it again.
Thanks,
Rokr_E6
Jan 12, 2009 | Motorola Mobility ROKR E6 Smartphone
It turns on and off and now it does not hold data or music
Hey,,,,,Charge it up completely,,,,and then load it up...The computer won't charge it up when you are using it. THEN CHARGE IT UP AGAIN. the battery is the size of a nickel.
Feb 22, 2008 | Coby MP-C758 512 MB MP3 Player
Dell Inspiron 1525 Notebook Logo
400 people viewed this question
Alun Cox
