Question about Galaxy Radios DX- 88HL Base CB Radio
I have Galaxy 88, worked fine last time I used it (couple yrs ago). Now I only get static, cannot hear or talk to anyone. I'm sure it is adjustment or antenae. What do you think???
    Champion:
  • 219 Answers
Sound like the antenna needs to be checked.Do you have a shop near you that will help.
Posted on Jul 20, 2010
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Tascam CD-RW4U
Try adjusting the input level so the meter stays close to 0 when recording. It sounds like the levels are too hot.
Aug 04, 2008 | Tascam CD-RW4U CD Recorder
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Static
This is probably high voltage arcing from your flyback transformer, distro xformer, or cables. They need to be checked and cleaned, then the source of the arc needs some hi - q dope applied. This is 30,000 volts we're talking about, so be aware you could kill yourself if you don't know what you're doing ! !
Scott B
Sep 17, 2007 | Toshiba TP50H60 50" Rear Projection...
Galaxy Radios DX- 88HL Base CB Radio Logo
90 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
